Fl Crew prayer circle please. I do not want a hurricane but I am prepared. Just off to change the propane tank and make sure I have a good supply of ciggies and alcohol!
As a native, I'm pretty much always prepared. The only thing I need to pick up is an extra 30 gallons of fuel for the generator, which usually winds up getting poured into the cage afterwards if it's not needed.
If Isaac does manage to get to S FL, it doesn't look like it will be more than a Cat-1, which is just enough of an excuse to have a hurricane party.
If it wreaks havoc on anything here, it will probably be the Repub convention in Tampa. Now, that could turn into a real cluster *****.
