Battery replacement
http://www.bohannonbattery.com/html/motbat/30lbs.html
Just my 2 cents worth...
I used an easy to find online coupon code (something like p20) and then went to the store for pick-up with my old battery in hand (core charge).
My old battery and new battery were identical in box size/shape.
The out the door price was under $120.
Take your old battery to the shop because some after market batteries require a plate/stand that is included in order to fit correctly.
I do not like to use a plate.
Mine did not require the plate /stand and i was able to compare my old battery to the new one at the counter in case purchase needed to be cancelled.
I have now done two bikes with the Advanced Auto parts battery.
Both bikes (Dyna & Road King) did require a goldish color washer spacer (included) at the battery lugs.
On the touring bikes..removal of old battery is easier if you screw old lug bolts into the top of (+) ( -) posts and then tie a non conductive string /zip tie/rope (old leather belt works well) to those posts and pull up.
I was going to order online but i wanted to "see" the battery first and in my case the difference in price was less than $20.
