The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
TOAK, The Thread of All Knowledge Part X
Old Oct 6, 2017 | 06:26 AM
  #7281
OKMICK's Avatar
OKMICK
While we're talking electrical I wanna go over something Dan suggested regarding my sprinkler controller box leads. He suggested loosening one end of the wires (I assume the end at the controller box) and wrap them together. Go to other end with multimeter and check circuit. I am not electrically inclined but without a power supply how can the wires show a complete/non-complete circuit?
Old Oct 6, 2017 | 06:27 AM
  #7282
OKMICK's Avatar
OKMICK
Mornin, Doc, you cheapskate. I sent Marcus a 5lb box of 100's!
Old Oct 6, 2017 | 06:28 AM
  #7283
Uncle Larry's Avatar
Uncle Larry
Originally Posted by gs34doc
A 5 pound box of 20's is always useful!!!
That's about $9100.00 Doc ... :>)
  #7284
BARACU's Avatar
BARACU
Big Kahuna HDF Member
Marcus, are you trying to shut the charger or the phone off? It's early and I'm confused.
  #7285
PapaThiele's Avatar
PapaThiele
Helluva suggestion! Knowing my wife and in laws I would get Ł5 and 20 pounds of scented candles
  #7286
Uncle Larry
Adios
Old Oct 6, 2017 | 06:29 AM
  #7287
ultracan's Avatar
ultracan
It should just show the conductivity of the wire. Don't know what you are looking for, but if there is a break in the wire then there should be no reading.
At least that is my guess?????
Old Oct 6, 2017 | 06:32 AM
  #7288
OKMICK's Avatar
OKMICK
My electrically challenged skill set is questioning how wires with nothing going through them can indicate a circuit. Where is the power coming from? Does wire have a natural electrical element to it that I am unaware of?
Old Oct 6, 2017 | 06:33 AM
  #7289
BARACU's Avatar
BARACU
Set the multimeter to ohms . If you get a reading then you have complete circuit which means that there is no break in the wires. By twisting two ends together, you're really making just one long wire. If needle doesn't move then you have a break in one wire.
  #7290
gs34doc's Avatar
gs34doc
Mick...use a multimeter and set it to check continuity. Make sure you disconnect the wiring from both ends then short the 2 wires at one end together. go to the other end and put a lead from the multimeter onto each wire. your meter should register a complete circut. if the needle does not move or shows ZERO...you have an open circuit.
