fuel filter, shell & top plate
Old Sep 21, 2014 | 11:42 AM
jefla's Avatar
jefla
Default fuel filter, shell & top plate
I'm collecting parts for changing my fuel filter. Threads here report shell problems and so I also will do the shell. Threads also suggest that the top plate may be the culprit in shell failures. I'd like to get guidance to all of this in one thread.
For a 2009 FL:
(1) Are there issues with the top plate and should the original version be changed?
(2) Can someone please provide the P/Ns for fuel filter, shell & top plate? Is there a kit?
I'm steering clear of the ring removal tool issue, but will say I am getting the Snap On (http://buy1.snapon.com/catalog/item....roup_ID=681633).
Thanks
Old Sep 24, 2014 | 01:28 PM
jefla's Avatar
jefla
Having rediscovered St Charles HD's parts finder, I can provide the part numbers and prices.
Filter -- 61011-04A $17.77
Shell : 62229-08B $31.36
Top plate: 75147-08B $137.03
Top plate assembly 75069-08C $137.03 (filter, shell, regulator, harness, top plate, etc.)
Obvioulsy it makes more senes to buy the top plate assembly.
The link for the parts finder is http://www.stcharlesharleydavidson.c...partfinder.htm
I still do not know if there are problems with top plates on 09 FLs. Anyone know?
Old Sep 24, 2014 | 02:14 PM
$tonecold's Avatar
$tonecold
For a 2009 FL:
Thanks
The part number is: 75069-08C. I replaced the whole top plate unit when I did mine. The one benefit to the top plate replacement is that it has a better filler neck. Much easier to top off the tank. Kutter has it for $114.00 shipped. http://www.kutterharleyonline.com/ha...tank-75069-08c
Old Sep 24, 2014 | 04:36 PM
jefla's Avatar
jefla
Thanks, $tone. I'm replacing the whole top plate unit.
Old Sep 24, 2014 | 05:26 PM
jdvorchak's Avatar
jdvorchak
Before I dropped $114+ I'd find out if it affected your model. I know my friends 08 Classic had the problem but was replaced on a recall.
Old Sep 24, 2014 | 05:47 PM
toothmansteveb's Avatar
toothmansteveb
I change the fuel filter on my 2009 FLHCU every 25 K. Only change filter and O ring. Now at 79K and no problems. The Cam Ring tool makes it a simple task.
Old Sep 24, 2014 | 05:56 PM
$tonecold's Avatar
$tonecold
I know my '09 FLTR had a defective filter canister because it failed, I almost didn't make it back to the house. I knew some other '09 FL owners that had the same problems. I don't think they did a recall, at least not to my knowledge, but changing the whole top plate was worth the money and I paid list plus tax for it.
This is a picture of the broken canister and the heavier duty replacement. The '08's had the 75069-08 version, the 09's were suppose to have the 75069-08A version, the '10's had the 75069-08B version, and the '12's came with a 75069-08C which is the current version available. I would say that there was still a problem with the A & B versions of some sort or there wouldn't be a C version, the MOCO usually doesn't just replace things that don't need replacing unless it saves them money.
You may want to check which version you have in your bike jefla before you change it out, but if the canister looks like the one on the left, change it.
Old Sep 24, 2014 | 07:46 PM
TUCCI's Avatar
TUCCI
This issue is only with the center fill models (SG, RG ) is this right?
Old Sep 24, 2014 | 08:13 PM
$tonecold's Avatar
$tonecold
Hey TUCCI, how you doin'? I don't think you will have anything to worry about with the '11 model, but it does use the same filter canister (shell) as the other FL's use. The top plate just doesn't have a filler hole in it. I think what may have happened is that some of the '09's were fitted with the 75069-08 top plates. I don't know this for sure, but the part number that is listed for the '09's has the beefed up filter shell.
Old Sep 24, 2014 | 11:43 PM
jefla's Avatar
jefla
Thank you all. I considered waiting until I had the bike apart before ordering the kit, but that's more down time than I want. More importantly, only -08C is listed for 2009 in current parts lists I've seen, and I am comforted by going with a redesigned unit.
