Replacing spark plugs on 2010 ultra classic for first time. Two quick questions:
1. What is torque setting when I tighten and install new ones?
2. Do I need to put anything on spark plug threads before installing?
IF (and I don't) use anti seize please use the high temperature stuff, the regular stuff is not made for high heat applications, it is the copper stuff that is
Permatex anti-seize lubricant 80208 is rated for use from -60 F up to 1600 degrees F. I think that might encompass the operating temperatures of a Harley.
+1 on anti seize. I just use the silver cause thats what we have sittin in the grage and its worked for me. Torque is as stated 12-18 ft lbs or snug dont over tighten as the threads are only aluminum.
Steel threads in aluminum heads--use anti seize. Even if you don't think you need it, the first time you have to have a helicoil installed, or worse yet replace a head, you'll know why. Torque--12 to 18
