Anyone remove the plastic catch from the tray that sits on the battery and holds the ECM from where the metal arm from the battery tray comes through? I have had it off several times and its almost always a pain coming off and going on. Maybe I just don't know the trick but I can see any reason to just get rid of the plastic part. Had a pic on my phone but can't find a cord to to transfer to the PC with....&$(* kids
Thanks
Thanks
Dont use it. I have a Thundermax, It completely"s replaces the ecm
it clips on top of the battery also, Where is it going to go? Make sure the wires are secure and let it go
The first time I tried to remove the tray I had the same problem. It seemed impossible to do.
The next time I clipped the tie wraps holding the wiring harnesses to the frame rails and everything came out easily. It looks like you should not have to do this but once the cables are moved a bit everything pops out easily.
