No more plug wires!!!
Old Oct 2, 2014 | 09:04 PM
Don81's Avatar
Don81
Originally Posted by fabrik8r
How do they interact with the OEM ion sensing timing control function?
No impact. The coil is just in a physically different location is all.
Old Oct 2, 2014 | 09:17 PM
fabrik8r's Avatar
fabrik8r
Its not just in a different location, its a different coil, actually two individual different coils. I didn't find any info from the manufacturer regarding the ion sense function. Do you have a source of reference for "no impact"?
Old Oct 2, 2014 | 09:28 PM
Don81's Avatar
Don81
Well, I know how ion sensing works which is enough to tell me there's no impact.
Ion sensing is about reading the conductivity of the plasma trail left behind after the spark event has created combustion. It can be used as an intrusive cylinder detection mechanism to determine things like misfires or knock.
The coil is just a means to the spark, the ion sensing comes in after the fact. It really doesn't matter if the spark source is different or even generated in a different fashion such as capacitive discharge vs. inductance.
EDIT: Unless of course the ion sensing circuitry is part of the factory coil, in which throwing that away will certainly have an impact. I'm not that closely familiar with HD's specific implementation, so there's no practical reason it must be married to coil but I suppose it's possible they physically designed it that way.
Old Oct 2, 2014 | 09:34 PM
TriGeezer's Avatar
TriGeezer
So...really...if there is no performance improvement, what's wrong with plug wires?
Old Oct 3, 2014 | 01:19 AM
fabrik8r's Avatar
fabrik8r
There is not a separate circuit, the ion sense function is read by the plug, back through the OEM coil.
Old Oct 3, 2014 | 04:41 AM
Campy Roadie's Avatar
Campy Roadie
Looks like a good way to trap heat that would normally migrate up and away from the combustion chamber. Not mention blocking wind passing over it. These engines run hot enough as it is.
Don't get me wrong friend. I'm not trying to kick down another man's barn; if it suits you, that's all that matters.
Old Oct 3, 2014 | 05:00 AM
lp's Avatar
lp
Most of the newer cars these days use the same tech. Separate coils on each spark plug so it's really not new. Cool to see on a bike though...
I think it looks great and I almost went that way myself when I needed a replacement coil.
I figure since the kit is made specifically for our bikes the manufacturer already thought of the hard stuff (Ion sense etc) and it doesn't look like it will hold any more heat than say a HD Head Fin bridge.
Rock on.
Old Oct 3, 2014 | 05:01 AM
Florida Swamp Yankee's Avatar
Yes, no issue there. That's what drove me to look at the coils as I had a recurring code for the rear cylinder. I had replaced my wires and moved the coil to where the horn mounts and then a few months later started getting intermittent codes. What it turned out to be was a scorched terminal post on the coil for the rear cylinder. I tried removing the crud from the post with a dremel tool that would fit down in the space, which in the end just made the code come up almost immediately.
Since I put these coils on, no more codes, no more pinging, mileage is up about 10 miles a tankful, and it doesn't even notice that the 'Ol lady is on the back or not, now that is a performance enhancement!
The way the coil holder is designed it has plenty of airflow as it is an extension of the head fins with a good sized space beneath the coil and holder and the top of the head. The coil "floats" on top of the plug via a wound spring type connector, while the rest of the holder rigid mounts on top of the head bolts on either side of the plug.
Old Oct 3, 2014 | 06:16 AM
cdestuck's Avatar
cdestuck
For me, I'd never add anything to block any air flow or trap any heat into the head area. I really like those chrome bridges they make to bridge the plug area. As hot as these engines run, I'm not doing anything to make it worse.
Old Oct 3, 2014 | 08:36 AM
Don81's Avatar
Don81
Sure there is, the traditional secondary circuit is modified with some zener diodes, then a parallel circuit with capacitance is added to push current through the ion trail after ignition, along with a sensing lead.
I see your point though, it does require that sensing lead tap off the secondary winding and I wouldn't call that common yet.
Just stick a wire inbetween the coil and the plug.
I'm kidding.
