Compensator / Starter
Old Oct 9, 2014 | 05:20 AM
Teut's Avatar
Teut
Originally Posted by prezflyr
can the inner primary bearing be changed when I change the compensator? Any special tools needed?
Yes and yes;look at the manual.
Old Oct 9, 2014 | 05:26 AM
Notgrownup's Avatar
Notgrownup
You starter going will more than likely go away after the compensator swap, mine did , but why swap a starter if it's fine? You can swap the starter without the primary cover being off. As far as inner primary bearing, it's a little more complicated that swapping it out.
Do you know if it's bad?
Old Oct 9, 2014 | 08:19 AM
prezflyr's Avatar
prezflyr
No I do not think it is bad since I have no symptoms. I was just thinking about changing it while I am changing compensator but it may b more than I want to do.
Old Oct 9, 2014 | 08:38 PM
Notgrownup's Avatar
Notgrownup
Yeah, it's a bit involved.
Old Oct 9, 2014 | 10:39 PM
decencyxdefied's Avatar
decencyxdefied
Yes it can be changed.. Just had mine done.. Didn't help a damn thing.. Still grinding one hot start ups
Old Oct 10, 2014 | 05:19 AM
Assegai's Avatar
Assegai
................. sounds like the starter clutch - $200 kit.
Old Oct 10, 2014 | 08:05 AM
prezflyr's Avatar
prezflyr
I just completed the SE compensator and Baker attitude chain adjuster yesterday. What a breeze of a job that was. I will also change the starter and what the Hell, new gaskets too. I guess if lucky I will get another 60K of maintenance free riding.
scot210
Oct 21, 2017 08:35 AM
RoadRich2010
Jul 31, 2012 09:52 PM
rlaf75
Oct 20, 2011 06:07 AM
byrdi
May 9, 2006 02:07 AM
Joker441
Shovelhead
Feb 8, 2006 04:56 AM
