Finally did my breather bypass (pics included)
Old Feb 26, 2017 | 01:46 PM
  #471
checkers's Avatar
checkers
My 2 cents: In leu of a "T" try do do it with a "Y" fitting. It will flow (scavenge) better and your breathers will not compete with each other.
Old Feb 26, 2017 | 03:49 PM
  #472
Cozz's Avatar
Cozz
Default Brown goo in vent line
I vented my head breather tubes to an element attached to the back side of my stock Ac backplate. After 4500 or so miles I noticed a few drops of oil on the cam chest cover. Took ac apart to have a look, and found this brown goo in the rear cylinder vent tube. It was nearly blocked with it. Thoughts ? I will now vent it to atmosphere.
The brown goo is oil, gases, and condensation ? Help...I need some answers!
Attached Thumbnails Finally did my breather bypass  (pics included)-img_0805.jpg   Finally did my breather bypass  (pics included)-img_0806.jpg
Old Feb 26, 2017 | 09:10 PM
  #473
RG Pilot's Avatar
RG Pilot
Correct!
Old Feb 26, 2017 | 10:42 PM
  #474
confederate's Avatar
confederate
Most Wanted
Originally Posted by GregGillette
My spin at a complete home made setup. Made my own breather bolts as didnt want to drill my Big Sucker intake and no one had long enough breather bolts. I have the luxury of space to hide under stock cover as I enjoy the stock look. Turned out better than expected. Im choosing not to use filter on the end. Can feel the air moving out the tube easily so its doing its job. Depending on the residue of oil on frame rail, may have to rethink exit angle or cut tubing with angle at end to direct downward.
Sure would be nice if DK Customs made some of these type of breather bolts for the big sucker for those who don't want to drill into them. Would make this modification even simpler. How about it DK???
Old Feb 27, 2017 | 05:08 AM
  #475
SBates08's Avatar
SBates08
This may be what your looking for.
https://www.hdforums.com/forum/touri...ig-sucker.html
Old Feb 27, 2017 | 02:47 PM
  #476
esteboatan's Avatar
esteboatan
Yes I think thats what it is. I see the same colour stuff at a loose connection to the breather filter.
Old Feb 27, 2017 | 03:18 PM
  #477
Cozz's Avatar
Cozz
What size tubing did you use? I used 1/4 i.d. Thinking that is what the factory used, why not? Now I'm considering 3/8. might be the way to go.
Anybody else found some of this brown goo in their breather system?
Old Feb 27, 2017 | 04:43 PM
  #478
Just Me's Avatar
Just Me
Pretty amazing all the different ways to do such a simple job.
Talk about over-engineering!
  #479
golfblues's Avatar
golfblues
"Anybody else found some of this brown goo in their breather system?"
That's what you're supposed to find in your system. I have a clear liquid at the bottom of my catch can but if I squeeze a paper towel on the sponge its brown crap
Old Feb 27, 2017 | 06:00 PM
  #480
Cozz's Avatar
Cozz
I guess what I was shocked to see was one breather line blocked, or close to it, with the brown sludge. Never expected that to happen. I' ll be checking it every month from now on.
