Wild 1 WO578 10" install ?
Old Oct 23, 2014 | 09:29 AM
troop's Avatar
troop
Default Wild 1 WO578 10" install ?
Decided to go with the W1 578's over KW 2+2 for my next bars. I already put a +4 clutch line and TBW extender on my current KW +2 sweepers so I'm set there. Now, I read where the stock upper brake line works by swiveling the fitting. I'm pondering a +2 or +4 to make it a bit cleaner and less taut. Would a +4 be too sloppy? They're both the same cost. Thoughts? Thank
Old Oct 23, 2014 | 10:16 AM
DXHD $100's Avatar
DXHD $100
I used the stock Brake Line no problems.
Attached Thumbnails Wild 1 WO578 10" install ?-007.jpg   Wild 1 WO578 10" install ?-new-bike-2.jpg
Old Oct 23, 2014 | 10:21 AM
user 8373900's Avatar
user 8373900
All that is needed is take it out of the present straps under the tank and tie it to the wire loom just below. Mine worked fine.
Mark
Old Oct 23, 2014 | 05:43 PM
ridedaddy's Avatar
ridedaddy
No brake line extension here either. The only thing I ended up extending was the clutch cable. The stock cable would have worked but I didn't like the way it had to be routed to make it work.
Old Oct 23, 2014 | 07:54 PM
BuzzL's Avatar
BuzzL
Me too, +2 on the clutch.
L88
May 2, 2017 09:53 AM
tmultra
Jan 2, 2017 11:36 AM
sorensentyler
Jul 8, 2014 09:34 AM
Northbound Southerner
Oct 8, 2013 03:08 PM
InsomniaInc
Jan 2, 2013 11:42 PM
