Driver Backrest
Old Oct 25, 2014 | 08:10 PM
tpcowfish's Avatar
tpcowfish
Originally Posted by Xcrossbow
For those that have one, will the backrest fit in a saddlebag?
I'd have to say yes, never put it in there, but fits easily into tour pak
Old Oct 25, 2014 | 09:14 PM
Xcrossbow's Avatar
Xcrossbow
Could you try it please? Have a SG with no tour pak.
Old Oct 25, 2014 | 09:29 PM
RushKing14's Avatar
RushKing14
I have one of those I use for my stock two up seat. You get everything you need, and install in 5 minutes tops.
It doesn't come loose, can be slid in and out in seconds.
Yes, it will fit in your saddle bag.
Works as advertised, and is comfortable.
There is no adjustment other than front to back by adjusting the bracket under the seat, so not convenience. However once you find the position that suits you, no need to really.
I new I was going to get a solo with backrest, so for me to spend 2-300 for a Harley backrest on the stock seat seemed absolutely nuts to me.
Old Oct 25, 2014 | 09:48 PM
Xcrossbow's Avatar
Xcrossbow
Thanks for the info RushKing.
Old Oct 25, 2014 | 09:56 PM
Rico Rose's Avatar
Rico Rose
I bought one ane have two buddies that bought them. Agree that it is a good product. Very comfortable. Went on a 4600 mile trip last year and was glad i had it. It will fit in the saddlebag. Also the latest one that a friend purchased does in fact adjust fore and aft about an inch. There were some on another post that questioned the durability and thought that support steel would bend. Mine must have a total of 10,000 miles and still looks new. I weigh 260 and push back on it all the time and the steel that supports you that slides into the bracket has never bent. I think it is made of spring steel.
Old Oct 25, 2014 | 10:07 PM
hdgzr's Avatar
hdgzr
I've got one, you can see it in my sig pic. Very sturdy and comfortable. There's an inch or so adjustability forward or back, but not up or down. Once you slide it in the receiver it stays put. And I agree, it does fit in the saddlebag, no problem.
Old Oct 26, 2014 | 04:17 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I picked up one for my Softail. It works well and is very comfortable for me. It is inexpensive. It is not adjustable. While the quality is fine, the finish/seams are not what you see on the more expensive units.
I got the one with a pocket in the back and Mary uses it when on back.
I did not like how it just slid in, so once I knew I was comfortable, I went ahead and drilled a hole and have it locked in place with a bolt/nut.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Oct 26, 2014 | 05:05 PM
schlacker's Avatar
schlacker
I wished they would have shaved a 1/2 - 1" off the foam as it pushed me too far forward.
Old Oct 26, 2014 | 06:47 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Yes, I agree. I forgot that was how I felt also. It was a simple matter of removing the cover, shaving off about an inch of foam and then stapling the cover back on.
Old Oct 26, 2014 | 07:55 PM
RushKing14's Avatar
RushKing14
I thought so too, so I took the seat back off, and turned the bracket around. That gave me another inch or so back. Luckily mine was on a touring bike and made this possible. Not sure it can be done on a softie bracket or not.
