Removed Fuel Gauge
Old Oct 27, 2014 | 08:51 PM
bcane98's Avatar
bcane98
Default Removed Fuel Gauge
Replaced my fuel gauge/air temp with tweeters on my '09 Ultra and now the low fuel light is on and fuel remaining shows r---
Any suggestions?
Old Oct 27, 2014 | 08:53 PM
SafetyMan's Avatar
SafetyMan
Put the fuel gauge back in.
Old Oct 28, 2014 | 05:53 AM
bcane98's Avatar
bcane98
Good point, but then I lose my left tweeter LOL...
Worst case I plug it back in, hide it inside the fairing, but that's just a bandaide. You can't tell me that no one has ever encountered this though.
Old Oct 28, 2014 | 06:27 AM
SafetyMan's Avatar
SafetyMan
I've never heard of anyone removing the fuel gauge.
I've seen them moved around, and the air temp and volt gauge taken out for speakers...
But I couldn't figure that out either. Maybe my ears aren't as "in tune" to the finer speakers. I've ridden one with extra tweeters, and the wind and engine noise still blocked most of the finer stuff out...
Old Oct 28, 2014 | 07:26 AM
Hecklerboy's Avatar
Hecklerboy
Pull the Volt gauge and replace it with the fuel gauge.
The volt gauge is almost useless, at least mine is.
You will really like that fuel gauge when you're on a long trip.
Old Oct 28, 2014 | 07:30 AM
roadking2014's Avatar
roadking2014
Wooof! you'll see it all and hear it all here.
Old Oct 28, 2014 | 08:09 AM
Boomer1143's Avatar
Boomer1143
You need to figure out what the resistance is that the guage supplies to that electrical circuit. Place a resistor in place of the guage and the light should go out. Right now the circuit is open because the guage is not in place. You need to complete that circuit. It may be as simple as placing a jumper across the connector. I would suspect that the fuel sending unit supplies the resistance and the guage just is a measurement of that resistance.
Old Oct 28, 2014 | 04:47 PM
bcane98's Avatar
bcane98
And that is what I get for not doing my homework! Gonna put the fuel gauge in place of the voltage.... I won't have any lights turning on cause that is missing?
Old Oct 28, 2014 | 06:25 PM
TWIN CAM 96's Avatar
TWIN CAM 96
The fuel gauge always works better using a stick.
Old Oct 28, 2014 | 06:27 PM
Northbound Southerner's Avatar
The battery light may come on...I would measure the resistance with a full tank and then put that resistor inline.
