Excessive vibration after head pipe swap
Old Oct 30, 2014 | 01:54 AM
Mixter's Avatar
Mixter
I did it originally in that order from the instructions
Old Oct 31, 2014 | 08:13 AM
hd_rolling's Avatar
hd_rolling
Make sure your slip-ons are tightened down to your saddlebag guards, if one or both are loose you will get some extra vibration.
Old Nov 1, 2014 | 04:00 PM
Mixter's Avatar
Mixter
Rechecked and re tightened all the bolts....it's rough at 1000rpm, worse at 1500, smooths out a bit at 2000, and then normal at 2500-3000....but at 1500 it's really bad!
Old Nov 3, 2014 | 12:20 AM
Mixter's Avatar
Mixter
Could it be the map that I'm using?
Old Nov 3, 2014 | 12:41 PM
MGS Performance's Avatar
MGS Performance
Former Sponsor
If the front exhaust is touching the right floorboard mount it can cause a vibration. It has happened to us before here in the shop.
Dont forget the motor is rubber mounted and it does move around in the frame. The exhaust is mounted to the motor. So if the exhaust is touching the frame it will cause a vibration.
Old Nov 3, 2014 | 02:27 PM
Mixter's Avatar
Mixter
I adjusted the floorboard. Removed the mufflers so it's just the head pipe. Still doing it.
Old Nov 3, 2014 | 04:02 PM
lp's Avatar
lp
Yes. It can definitely be the tune. Can you put your old header on and re-test. I know it's a pain but it's something you can do on your own...
Old Nov 3, 2014 | 07:49 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
check the o2 sensors make sure ya didn't get em switched up.
Old Nov 3, 2014 | 11:32 PM
Mixter's Avatar
Mixter
They seem to be fine....I'm going to play with the switching the map a bit tomorrow. See if that helps. IF not I guess I'll uninstall and reinstall the header
Old Nov 4, 2014 | 07:40 AM
lionsm13's Avatar
lionsm13
Changed out my 09 stock H/P for the Rinehart S/L duals too but did not notice any extra vibes.
I did notice a gain in HP/TQ though and that was with the same map.
Happy about that!!
fuelmoto
Apr 16, 2017 11:06 AM
narfical
Exhaust System Topics
May 19, 2014 04:18 PM
MTJM89
May 13, 2012 10:12 PM
fxdx-matt
Apr 27, 2012 09:11 PM
quackhead
Jun 2, 2008 05:57 PM
