Grip changing?
Old Nov 10, 2014 | 09:23 AM
EasTexUltra12's Avatar
EasTexUltra12
Default Grip changing?
I've got a set of HD Get a Grips that I'm going to be putting on my '12 Ultra and have a question about the procedure. Started with the left side, loosened the clutch lever, and removed the screws on the switch housing. Switch housing wouldn't come apart. It's very possible that I just didn't try hard enough. I've never done it before and have no idea how hard you have to pry to get the two halves of the switch housing to separate. I've seen the You Tube videos and it seems that they come apart pretty easy, but mine don't seem to want to.
Thanks for any help.
David
Old Nov 10, 2014 | 09:28 AM
TWIN CAM 96's Avatar
TWIN CAM 96
It may take a small screwdriver to pry lightly apart.
Old Nov 10, 2014 | 07:59 PM
oc1014's Avatar
oc1014
Did you remove all four of the screws or just the top two?. Remove all four and it should open right up.
Old Nov 10, 2014 | 09:34 PM
rdam's Avatar
rdam
Not to hijack, but I've got a set of part #56100036 Black Magnum Get A Grips for TBW touring bikes. Off my "Old" 2013 RK and barely used...Look new. $45 Shipped. PM
Old Nov 10, 2014 | 09:53 PM
EasTexUltra12
I removed 2 on the hand lever, and 2 on the switch housing. If there are 4 on the switch housing, then I haven't removed them all. Don't see how I could have missed 2 screws, but it looks like I did. Thanks!
David
Old Nov 11, 2014 | 06:15 AM
Gunnysgt's Avatar
Gunnysgt
Torx 25s on the switch housing, torx 27s on the clutch bracket. The newer bikes are also a bit trickier to change the brake lever, you need to darn near remove both the switch housing and front brake bracket to get enough room to "unhook" the lever from it's position.
Old Nov 11, 2014 | 06:22 AM
decencyxdefied's Avatar
decencyxdefied
Dk y the clutch lever has go be loosened. Few screws and ur done
Old Nov 12, 2014 | 09:11 AM
Joe12RK's Avatar
Joe12RK
When you do the brake side - use the prescribed wedge under the lever to prevent breaking the brake light $witch!
Old Nov 12, 2014 | 09:16 AM
EasTexUltra12
Yep, thanks.
Old Nov 12, 2014 | 09:34 AM
Gunnysgt's Avatar
Gunnysgt
I do hafta hand it to Harley on the brake switch, they aren't anywhere near as delicate as they were around 06, it was a very small plastic pin then and real easy to snap off. Much more sturdy switch now. I just put a set of levers on my '15 King yesterday
royston
2014-2024 Touring Models
Oct 5, 2015 12:46 PM
spf62
Jun 22, 2014 08:36 PM
bpd138
Apr 25, 2014 03:59 PM
Cornel
Oct 27, 2011 05:56 PM
p8nter
Jan 26, 2010 11:27 PM
