Road King on a diet
Old Nov 11, 2014 | 05:23 AM
Def Mute's Avatar
Def Mute
BOB IT!
(No, I did not say Bobbit)
Old Nov 11, 2014 | 06:05 AM
bikerlaw's Avatar
bikerlaw
Lower the bike. Front and rear. I lowered my barge simply for looks, and the ability to maneuver in tight spaces, both forward and backwards was a welcome side benefit.
Old Nov 11, 2014 | 06:29 AM
mtiberio's Avatar
mtiberio
what I did to make my police bike more manageable.
get rid of sprung saddle
get a narrow saddle
install 12.5" shocks
wear boots
removed:
rear crash bars
saddle bag rails
radio rack (installed a softbrake under taillight tag mount)
rear fender stay trim
front fender rubber bumper and trim
rear fender rubber bumper and trim
tach
light bar
heel shifter
Do all that and you will feel a difference. Also the one tip about pumping the forks works, plus you can get off the bike, and lean the saddle into your butt, and back up just about any bike on gravel, etc.
Old Nov 11, 2014 | 09:00 AM
Rampant's Avatar
Rampant
Sounds like buying the mustang low was a good choice. I'll be yanking off the extra doo-dads soon as well. We'll see how it goes.
Old Nov 11, 2014 | 09:09 AM
MikeBel's Avatar
MikeBel
Lowered my RKC with Progressive Monotubes w/ 1" lowering up front, Street Glide shocks 1" low on back, and a MCC seat mod that gave me an additional 1+" lower seat height. Made a huge difference for me on being able to move the bike around, and I'm a lot smaller than you.
Old Nov 11, 2014 | 09:33 AM
Eunoterpsia's Avatar
Eunoterpsia
Originally Posted by Fathead2003
Install reverse gear .
LMAO - Best Suggestion!
To the OP... is removing 50lbs... really going to make a difference on a 850lb bike?
Get rid of your LE Seat set up and put on 12.5 rear shocks!
Old Nov 11, 2014 | 09:56 AM
c130loader's Avatar
c130loader
Originally Posted by heritageblue2013
Being it's a cop bike, could you not justify ridding two up with another man saying you were taking him into custody? Then when you get stuck you have help?
Old Nov 11, 2014 | 10:00 AM
Rampant's Avatar
Rampant
Originally Posted by Def Mute
BOB IT!
It's been considered but I don't have time/space/equipment for all that.
Old Nov 12, 2014 | 09:09 AM
Joe12RK's Avatar
Joe12RK
A helpful hint - you may already do this - when I had the cop seat I found it easier to back up by reaching down and grabbing the top of the saddle bag crash bar for better leverage. Pulling back on the handlebars wasn't as effective. Joe
Old Nov 12, 2014 | 09:16 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
A bike weighing in at close to 800 pounds is still a very heavy bike, even with a 100 lbs pulled off (which isn't a realistic weight loss).
Reverse isn't cheap, but it sure is effective. I'd love to find a used one cheaply at a swap meet, but that hasn't happened yet.
Lowering the seat or the bike, or both, gives you a lot more leverage to shove it backwards with your feet while straddling it. But, it's still a heavy beast and it's just not easy unless you're on smooth level ground. Which as you know, the world is not always covered with.
