Replacing compensator
Old Nov 12, 2014 | 04:44 PM
prezflyr's Avatar
prezflyr
I just replaced the stock compensator in my 09 Ultra with a new SE Compensator. It Came with rotor, springs, needle bearing, plastic oil deflector and everything and made a world of difference in my bike hot or cold starting and killing.
Old Nov 12, 2014 | 06:05 PM
sg2007's Avatar
sg2007
Prez were you able to buy the glue from Harley for the plastic funnel,been reading up on part numbers and none available.
Old Nov 12, 2014 | 06:33 PM
prezflyr's Avatar
prezflyr
I ordered the same glue that Harley uses from Chembar glue made by Lord.
Old Nov 12, 2014 | 06:46 PM
jefla's Avatar
jefla
I'm going to do the same this winter. I have read many how-to threads on this and have HD and other manuals, but still I'm going to ask if you have any insights on the project? Frankly, I'm a bit apprehensive tackling this one.
Thanks
Old Nov 12, 2014 | 07:09 PM
prezflyr's Avatar
prezflyr
It is not a bad job at all it you have everything that you need on hand. Grinding the case to clear the rotor was a little touchy but not a big deal as long as the grinder does not get out of control. Make sure you have a T-70 Torx socket and a new gasket. I did also replace the HD primary chain tensioner with a Baker attitude manual adjuster. I think that was money well spent. My bike has never cranked or shifted as good as it does now. Stay on the forum and you will be fine.
Old Nov 12, 2014 | 07:50 PM
sg2007's Avatar
sg2007
Thank Prez,heard that glue is pretty expensive.
Old Nov 12, 2014 | 09:50 PM
limboglide's Avatar
limboglide
Originally Posted by sg2007
Thanks for all the great info guys,I'll get both just for peace on mind. Limbo where did you purchase your comp,these guys at this dealership probably tryin to take me for a ride!
Purchased mine at San Jose Harley. I did not even think you could purchase the spring pack separately, I personally would purchase the whole assembly.
Old Nov 12, 2014 | 09:53 PM
limboglide's Avatar
limboglide
What scoot do you have prezflyr where you had to grind the case? My 11 FLHX did not need that, just curious.
Old Nov 12, 2014 | 10:31 PM
prezflyr's Avatar
prezflyr
I have a 2009 Ultra classic. The rotor would not pull off without grinding the lip from the inner primary. Not much but 9:00 to 6:00 had a small lip that needed to be removed. It took 10 minutes to burr it off and 20 minutes to tape off the clutch area. Glue cost about $25 but Harley would not sell it and it is a one time shot so what the heck. The way it changed my bike made it all worth it.
Old Nov 13, 2014 | 12:23 AM
Guntoter's Avatar
Guntoter
The H-D part numbers for the adhesive and applicator are 11100088 and 11100075 respectively. At one time they were available for purchase through a dealer but I don't think they are anymore. Might check some of the online 20% off dealers and see if any still do.
Alternative is to take the cover and plastic funnel to your friendly local dealer and pay them to install the funnel.
