cam confusion
Old Dec 6, 2014 | 07:12 PM
jrat69's Avatar
jrat69
Default cam confusion
I know there are many cam discussions, and I have read through many of them, just wanting some fresh opinions. 2012 RK 103 I've done the AC and decatted, and running a map from Fuelmoto and auto-tuned with my powervision. I run from Idle to 4000, rare to go to 4500. Just wanted more low end and better use of 6th gear. I was looking at the Andrews 26, and the S&S 551c. I called Gary at Andrews and he said I should look at the 57. I would loose some of the low end, but it worked better in a 103, and if I wanted low end I should look at gearing. I called S&S, and they recommended going with the MR103, here again saying it did not have as much low end as the 551, but worked better in the 103. Most people say they get great low end and overall good results with the SE255, and it seems to be better suited for me. I wasn't wanting to stick with a compliant cam. Anyone have any reports on these cams? I'm not doing any head work, or wanting a race bike. I have read that the Andrews 57 makes the bike a little harder to start, don't know if it's true.
Old Dec 6, 2014 | 07:17 PM
dawg's Avatar
dawg
Have you thought of the TW-222?
Old Dec 6, 2014 | 07:41 PM
dforeid's Avatar
dforeid
I was in your shoes completely. I wanted a good torque cam. Tons of research later, I went with the Woods TW-222. I ordered it from Fuel Moto and did the install myself. Couldn't be happier. Runs really strong in the low end, but carries it up to the right far enough for my liking. I am very happy with this cam choice.
Old Dec 6, 2014 | 07:44 PM
ALUCARD19's Avatar
ALUCARD19
[QUOTE=dawg;13476076]Have you thought of the TW-222?[/
++1 on the TW-222 cams great low end torque and don't run out of steam until 5200 rpm.
Talk the guys at fuel motor or call Bob Wood from woods cams.
They are ground by Andrews to Bob wood specs.
Old Dec 6, 2014 | 07:49 PM
stro1965's Avatar
stro1965
I like Andrews. Pass the 57 sauce please.
Old Dec 6, 2014 | 07:57 PM
Ben E's Avatar
Ben E
With a 107 the 555 is very strong, comes on just before 3,000 and really rips in the midrange. With 103 i'd really consider the 222. All good reports...
Old Dec 6, 2014 | 08:01 PM
Boomer1143's Avatar
Boomer1143
I am running the 255 cams and am very happy. I have plenty of low end torque. I'm like you in that I run up to around 4k rpm but rarely over. Good luck with your decision.
Old Dec 6, 2014 | 08:27 PM
dochawken's Avatar
dochawken
+1 on the 57
Old Dec 6, 2014 | 08:48 PM
KSGLIDEGUY's Avatar
KSGLIDEGUY
[QUOTE=dawg;13476076]Have you thought of the TW-222?[/QUOTE
My thoughts excactly. Best low rpm touring cam IMO.
Old Dec 6, 2014 | 09:35 PM
bklynbob's Avatar
bklynbob
Default Andrews 48
Great cam in stock 103
Even better with headwork and a couple clicks of compression:
