Pulling trigger on LED'S
Old Dec 15, 2014 | 07:36 AM
crimson13's Avatar
crimson13
Originally Posted by painey
Got another option, I have the Trucklite but I used LED bulbs in my driving lights instead. Prefer the look and much cheaper $65 a pair. All just plug n play
http://www.socalmotogear.com/Harley-...ED-p/hdled.htm
Shown with my Trucklite and CD turn signals (they go amber when turning)
Good looking ride. Thanks for the link.
I was under the assumption that the Truk Lite headlight and passing lights were plug and play.
Old Dec 15, 2014 | 09:17 AM
just plain john's Avatar
just plain john
I had to add a 1/4 inch female quick disconnect to the ground wire on the driving lights
Old Dec 15, 2014 | 09:30 AM
96roadking's Avatar
96roadking
For your headlamp you'll probably want the "frenched" style trim ring. Part Number 69623-99A. The trucklite lamp protrudes forward more than the stock one and this trim ring will cover that extra protrusion. This was all plug and play otherwise for me on my 2012 King. I also installed the Kuryakyn total control passing lamp harness which allows the passing lamps to be on with the high beams. Kuryakyn 5496 Total Control...
Old Dec 15, 2014 | 10:04 AM
OLDDEADEYE's Avatar
OLDDEADEYE
Originally Posted by decencyxdefied
Will it go bang when u pull the trigger?
It'd be a unique way to turn on your lights.
Old Dec 15, 2014 | 02:40 PM
jlgale's Avatar
jlgale
The Truck Lites are plug and go. I am not mechanical at all and I installed mine. I did get the Halo ring because the headlight protrudes out. Many go with the frenched ring. I figure more lights the better to be seen. Still trying to get the courage up to try and install the halo ring
Old Dec 16, 2014 | 09:33 PM
5th Gear's Avatar
5th Gear
Will the truck lite headlight still install properly without the Frenched style trim ring? I assume the light just sticks out abit more?
The harness from Kury, where abouts does that get installed... inside the housing of the headlight itself?
Thanks
Old Dec 17, 2014 | 07:01 AM
mikelikesbikes's Avatar
mikelikesbikes
Thanks
Correct twice. As far as sticking out, I couldn't get to the dealership for the correct ring fast enough.
Old Dec 17, 2014 | 07:13 AM
96roadking's Avatar
96roadking
Thanks
Mine was installed and sticking out for a year before I saw a post on here about the frenched trim ring, sure makes it look better! the total control harness goes inside the headlight housing. THe only trick to installation is removal of the toggle switch to change routing of one wire.
Old Dec 17, 2014 | 08:11 PM
5th Gear's Avatar
5th Gear
Was there any wiring instructions with the wire harness.
Old Dec 17, 2014 | 10:05 PM
ALUCARD19's Avatar
ALUCARD19
I got mine from these guys on E-Bay drivetrain america for $337.95 with free shipping.
Just plug and play it took me a whole 15 minutes to put in all 3 lights, the 7" headlight and the 2 4.5" passing lamps.
