Headset help
Old Dec 29, 2014 | 07:45 PM
Soupclub's Avatar
Soupclub
4th Gear
Default Headset help
Have a big trip coming up and need some help with communications. I have a 06 Ultra, other bike is a 12 SG. Both have CB's, am interested in what everyone else is using. This is the first trip for me using bike to bike communications, normally travel alone. I currently have a handheld mic as helmets are optional in Ohio and I've never really used it.
The questions I have are:
Is there a good bluetooth add on that is compatible with the stock music/CB so a phone can be incorporated ?
Will be using a mix of helmets, ( 1/2, 3/4, full ) as most of the states we are traveling thru require them, is the HD headset good or is there an aftermarket setup that's better ?
This will be about a 6K mile trip so whatever we decide on we're stuck with so I figured I'd ask the experts. There will be a number of large cities to get thru so communications is essential.
Thx in advance,
Old Dec 29, 2014 | 10:08 PM
hattitude's Avatar
hattitude
I searched and tried several ways to use the OEM Harley comms system on my '12 Limited.
I use the comms to talk with my better half, she is my passenger, while we are doing multi-day trips. I haven't use the comms to go bike to bike yet...
I don't wear a helmet unless I have to, and then I usually wear a very small beanie... but realized I need a helmet of some type to use the comms.
I tried the HD half helmet comm sets... they suck! If they work, they are extremely uncomfortable after about 40 min. I sold them and one broke during shipping(in OEM packaging) and I had to refund the money...
I finally purchased a couple 3/4 helmets and use the J&M comms system. The speakers are super clear and the mike works great. They have systems that plug into various makes of motorcycle comms
http://www.jmcorp.com/ProductDetail....EHI787-LDC-XHO
I researched being able to use my phone via bluetooth, to make/receive phone calls on a cross country trip. In 2012, the only way I found to do this was with the HD Bomm interface. I never used it, decided I didn't need to talk with anyone that bad... but it got good reviews by several people on this forum I believe.
http://www.hdbomm.com/Phone.html
Of course, I have read that there are many good bluetooth set-ups that will work well, and they don't use the HD comms system... but I haven't tried any of those.
Good luck with whatever you decide..
Old Dec 29, 2014 | 10:55 PM
JMJOHN's Avatar
JMJOHN
Sponsor
soupclub ,,,,,
very applicable short video here
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old Dec 29, 2014 | 10:58 PM
user 8373900's Avatar
user 8373900
Thx in advance,
Just get a mic for the handlebars. A lot less foolun around
Mark
Old Dec 30, 2014 | 06:52 AM
santajim's Avatar
santajim
The OEM headsets work fine. I have them on 3 different helmets including half helmets, the 3/4 helmets ones can be made to fit half helmets with a little ingenuity
Old Dec 30, 2014 | 07:32 AM
billnourse's Avatar
billnourse
I have the HD half helmet headset, and a J&M set in a 3/4 helmet. The 1/2 works okay, but the sound quality is not great for music and it gets uncomfortable. The solution we found for this is to just hang the headset around your neck so the mic is available, and listen to music, CB through the bike speakers. You can hear the CB and stereo good, and the mic is right there so you can talk. You will not be able to hear rider to passenger through the external speakers however.
The 3/4 J&M leaves some to be desired for music quality. Hardly any bass, but a step above the HD's. Something to remember is to always get the speakers as close to your ears as possible. When J&M installed mine the speakers were too deep and sound quality was terrible. I put spacers in to get the speakers closer to the ears and it helped, but still not ideal.
As far as phone use goes, if you have a Garmin 660 or 665 and interface it with the Harmon Kardon, you can make and receive calls as long as you plug in to the AUX port on the front of the radio, and have the radio in the AUX mode. Just don't expect it to work great. You will be able to hear perfectly, but the person on the other end will have problems because to the wind noise on your end.
I used to hate to wear helmets, but since we got the bikes that talk and have sound, I find that I wear a helmet most of the time and am not bothered by it like I used to be.
Bill
Old Dec 30, 2014 | 10:06 AM
Soupclub's Avatar
Soupclub
4th Gear
Thank you all for some great feedback. Sounds like I might have to go with both a headset and the handheld setup. I really appreciate everyones experience to base a decision on, thanks again and Happy New Year all !!
hillcountryflt
2014-2024 Touring Models
May 29, 2018 12:42 PM
justgeorge
Apr 21, 2017 11:36 AM
paid4c4
Mar 4, 2017 07:23 AM
SafetyMan
62
Apr 1, 2015 06:49 PM
rookierider
Feb 7, 2006 01:23 AM
