Installing Apes...?
Old Jan 5, 2015 | 09:20 AM
Rfc's Avatar
Rfc
Default Installing Apes...?
Got some 14" Chubby outlawz and decided to attempt the install myself on my Road Glide. I've read 4"+ cables/wires will be needed and wanted to know what you guys recommend... Any tips appreciated.
Old Jan 5, 2015 | 09:30 AM
Roadie13's Avatar
Roadie13
+4 should be good, but double check with John at Wild 1 just to be safe. I used the NAMZ wire extensions even though I really didn't need them for 12s - very good product. Also highly recommend SE throttle cable wire to get rid of the infamous green connector.
Old Jan 6, 2015 | 09:55 AM
Rfc's Avatar
Rfc
Excuse my ignorance but does the gas tank have to be removed to replace the front brake line/lines?
Old Jan 6, 2015 | 10:08 AM
user 8373900's Avatar
user 8373900
Add new polyurethane bushings to your shopping list. You'll have a much more solid feel with the taller bars.
Mark
Old Jan 6, 2015 | 10:14 AM
Rfc's Avatar
Rfc
Mark
Yep got that covered just wondering if the tank needs to be removed for easier access...
Old Jan 6, 2015 | 10:17 AM
user 8373900
Yes. For no other reason than to get it out of the 'drop zone'. Your front brake line is strapped to the backbone. You may be able to fish the new one, but what a mess!
Mark
Old Jan 6, 2015 | 10:44 AM
RaceFace's Avatar
RaceFace
Also, a good strong pair of snap ring pliers. Apparently mine were "borrowed" and I didn't realize it until I was knee deep in the job. Good luck!!
Old Jan 6, 2015 | 11:03 AM
SBates08's Avatar
SBates08
If your bike has ABS then yes it must come off. If no ABS then no it doesn't have to come off. I'd remove it just for sake of not getting it dinged.
2010 Limited with some stuff!!
Old Jan 6, 2015 | 11:48 AM
Rfc's Avatar
Rfc
Thanks man, mine is non abs sorta of a relief I don't have to remove it but will cover it good. See you're from Mississippi , cool.
Old Jan 6, 2015 | 11:52 AM
SBates08's Avatar
SBates08
Yessir. Where are you in good ole Mississip??
