Read the full discussion below to find out actual differences and make sure to check your local laws.
gut the cat?
Most are happy with just getting rid of the burning hot cat.
But an easy fix for those issues post removing cat and or adding pipes and maybe better breathing air cleaner would be Nightriider's
Xied's or Vied's or RC Componanats XCellerator fuel management system neither of which require any additional mapping or expensive dyno tuning time,ect,bolt on,plug in, & go!
Either of those systems will fix the extreem lean cond ,but the go about doing that using 2 totally different approaches ,check them out to see the difference in design.
The cheaper of 2 systems should cover stage 1 type mods (cat removed-slipons-perf aircleaner) but it's really meant for hot setups with more compression,perf cams and better breathing heads etc.
The 2nd much more expensive system should handle that + mods like aftermarket cams & heads etc as long as you have injectors that have enough capacity to properly supply the additional power adders but to be safe ask the mfg about that if you plan to go that route now or in the future.
BTW,if you want to keep your original head pipes with cat in tact you can buy stock original headpips that have had the cat removed on ebay for $100-150 on avg,cost me $100 for stock head pipes with cat removed on ebay for my 09 FLHTCU .
I pasted the links below so you can check out the fuel enrichment devices.
Scott
http://www.nightrider.com/parts/
http://www.rccomponents.com/blog/rcx...gement-system/
I recommend getting rid of the cat (I went with Power Duals) as a part of a performance upgrade package to maximize what you have at that time to work with.
