Question about wind deflection
Old Jan 17, 2015 | 08:11 PM
SWThomas's Avatar
SWThomas
Default Question about wind deflection
So I have the fork mounted wind deflectors (fangs) and the center baffle on my 04 RK. I have noticed on several rides on the interstate that the wind turbulence is a lot less when I keep my feet on the foot boards and squeeze my legs against the tank. As soon as I spread my legs away from the tank there's a noticeable increase in wind turbulence. Very noticeable with my feet on the pegs. I wouldn't really call it buffeting, but it's noticeable around my head.
Would installing soft or hard lower fairings block this wind that seems to be coming up the sides of the tank?
Old Jan 17, 2015 | 08:36 PM
hdbob2006's Avatar
hdbob2006
I can't stand my lower fairings,they block too much wind. They're off and will stay off. And Thank You sir,for your service!!!
Old Jan 17, 2015 | 08:40 PM
SWThomas's Avatar
SWThomas
Thanks for the reply.
Do they only block wind on your legs? Or do they also block some of the wind coming up the sides of the tank?
Old Jan 17, 2015 | 08:44 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
That's the air rushing straight up your legs and torso and then hitting you in the face.
Old Jan 17, 2015 | 09:00 PM
mikelikesbikes's Avatar
mikelikesbikes
Quite common. Even worse using highway pegs.
Remarkable observation.
Old Jan 17, 2015 | 09:11 PM
TSheff's Avatar
TSheff
Ditto - rode my Ultra home in 09, took the lowers off, wrapped them, stored them, and there they are today. Even freezing I wouldn't put them on.
As far as turbulence always there, tried all in RK except lowers. If you do block wind with lowers get ready to toast your legs in the summer.
Old Jan 17, 2015 | 09:16 PM
SWThomas's Avatar
SWThomas
Is there a way to block some of it?
Old Jan 17, 2015 | 09:28 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Both soft lowers and hard lowers will block a good deal of it, but not all of it.
A Tank Lift will reduce it some also.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Jan 18, 2015 | 01:47 AM
RKZen's Avatar
RKZen
I don't have the fork fangs but the hard lowers. It helps protect my legs except for the tops of the thighs. I'm not much a fan of the fangs.
Old Jan 18, 2015 | 07:17 AM
Keithhu's Avatar
Keithhu
Not sure how they would look on a road king (but then again you might not care because you are running those lovely fangs), but these road glide engine guard deflectors work great. Probably best with hard lowers tho.
I had hard lowers on my King, they were great, and they block a lot of wind.
http://www.harley-davidson.com/store...-deflector-kit
