Question about wind deflection
Old Jan 18, 2015 | 08:44 AM
SWThomas's Avatar
SWThomas
Thanks for the input fellas! I think I'll try a set of soft lowers and see how they do.
Old Jan 18, 2015 | 09:28 AM
cass's Avatar
cass
i have a pair of desert dawgs on my yamaha and they work pretty good...plus you can remove them when its nice out.
Old Jan 20, 2015 | 04:55 PM
leadermc's Avatar
leadermc
Former Sponsor
Default Soft Lowers Reduce Updrafts
Like Kevin said, soft lowers can block a lot of those updrafts. And like Cass pointed out, they are easily removed when it's hot and you DO want more air. Here's a link to the brand that Cass mentioned, the Desert Dawgs, made in the USA! http://www.leadermotorcycle.com/harl...n-rain-guards/
Old Jan 20, 2015 | 05:49 PM
hdbob2006's Avatar
hdbob2006
I don't know why,but I think hard lowers look better on a RK than they look on an Ultra.maybe just "too much" body area on the front of an Ultra?
Old Jan 20, 2015 | 06:45 PM
Northbound Southerner's Avatar
I have lowers on my Roadking. They are really good at blocking wind and I don't feel anymore heat in the summer with them on. I live in Biloxi, MS and it doesn't get much hotter and more humid than this place...
Old Jan 20, 2015 | 07:49 PM
shakrr's Avatar
shakrr
I agree mouth in the mid 80s I open the vents, have noticed with them closed it lowers my oil temp 2 degrees per side on my temp sensor on the filter housing
Old Jan 21, 2015 | 05:48 AM
BoonDock_Saint's Avatar
BoonDock_Saint
I have noticed on several rides on the interstate that the wind turbulence is a lot less when I keep my feet on the foot boards and squeeze my legs against the tank. As soon as I spread my legs away from the tank there's a noticeable increase in wind turbulence. Very noticeable with my feet on the pegs. I wouldn't really call it buffeting, but it's noticeable around my head.
Would installing soft or hard lower fairings block this wind that seems to be coming up the sides of the tank?
That's true with or without lowers. Yes, the lowers will lessen that breeze but not eliminate it. Once you put your feet on the highway pegs all bets are off.
My experience with soft lowers is: they suck. There's a reason nothing on the front of your bike is flat. Putting two big flat sails on your crash bar isn't going to help your situation.
Old Jan 21, 2015 | 07:00 AM
SWThomas's Avatar
SWThomas
I'm currently running the Kuryakyn floorboard reloactors with HD extended pans. Put the boards 2" forward and 1" out. I'm also running a 2" extended brake pedal and a 2" extended shifter.
Does anyone have this combo, or something similar, and can tell me if soft or hard lowers will still fit?
Old Jan 21, 2015 | 07:14 AM
TKDKurt's Avatar
TKDKurt
Is there a way to block some of it?
Get in a car and roll up the windows?
Old Jan 21, 2015 | 09:28 AM
SWThomas's Avatar
SWThomas
DarkMatter
May 14, 2016 01:05 PM
HDBri
Aug 12, 2014 04:23 AM
ejvette
Nov 5, 2013 09:18 PM
OldArmy
Oct 16, 2008 08:34 PM
mirage2521
Sep 17, 2006 12:53 AM
