Wind Buffeting
Old Oct 14, 2008 | 06:10 PM
OldArmy's Avatar
OldArmy
Default Wind Buffeting
All,
I have a Street Glide which does everything I want with one exception. Wind coming under the batwing and up into the cockpit when I have my feet up on the highway pegs is pretty bad--many times worse than when I'm on the floorboards. What if anything have you done to keep the buffeting under control without unduly restricting airflow over the engine? Thanks
Old Oct 14, 2008 | 06:15 PM
rshute4's Avatar
rshute4
Theres a part that goes between the forks and the tank (front fork air baffle?) it kind of helps but i have yet to find ANYTHING that makes it really any better.
Heres the link to HD
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old Oct 14, 2008 | 06:21 PM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
When its windy , Your going to feel it because the wind is also pushing on the fairing
Old Oct 14, 2008 | 06:25 PM
AaronOregon's Avatar
AaronOregon
Former Sponsor
Best thing I have done is get the wind deflectors that go right underneath the batwings for $30 through the dealer. Yes...............believe it or not you can get out of the dealership for under $100! I think they come in clear, tinted, and black! Really helped out I feel! Good luck.
Aaron
Old Oct 14, 2008 | 06:33 PM
Bertk's Avatar
Bertk
+1 for the air baffle.
Nitzo's Avatar
Nitzo
Aaron
+1....................I got a set off of e-bay and the ones I have are hinged so you can open and close them, similar to the UC's.
Old Oct 14, 2008 | 07:28 PM
MNPGRider's Avatar
MNPGRider
Get the fork deflectors, fork baffle, and install the adjustable batwing "wings."
The fork deflectors make the biggest difference, but also block the most wind to the engine, so I only run them in fall and spring.
Old Oct 14, 2008 | 07:31 PM
Streetrunner's Avatar
Streetrunner
I have lower fairings, fork baffle and fixed air deflectors that I use in cooler weather. Works prety good.
Old Oct 14, 2008 | 08:35 PM
jackinthebox's Avatar
jackinthebox
I have the fork baffle and it works. It also make it a little warmer, I had mine on during the summer for a little while then took it off. Just put it back on last week since its starting to cool down
Old Oct 14, 2008 | 09:29 PM
ElectraLarry's Avatar
ElectraLarry
Go for the cheap easy fix first. The wind deflectors on the bottom of the Bat Wing are cheap and simple. Then if you don't like them your not out much. I have them on mine and you can hardly notice them - see pic below.
