Screamin eagle clutch spring is definetly stiffer
Old Jan 19, 2015 | 07:54 AM
Belanger14's Avatar
Belanger14
Originally Posted by mtiberio
spring color/pounds per inch chart (I believe): SE (no color) 386# police (pink) 364 # stock 103 (yellow) 320# stock 88 (blue) 300# lite (white) 257# I had the pink in my bike, but it caused the pin in my wrist to loosen up and gave me huge carpal tunnel. I now have the blue... My bike is a stock police 103. and I can say while it doesn't slip, it feels less "snappy" on hard shifts. If I had to get more grip, I'd remove the judder spring and put a full width friction plate all the way on the inside.
Wow so the stock 103 spring is no where near the screaming eagle spring
Old Jan 19, 2015 | 08:07 AM
harley#1's Avatar
harley#1
maybe try the clutch wiz with their 480 spring. sounds like a win/win solution.
Old Jan 19, 2015 | 08:09 AM
Smokey Stover's Avatar
Smokey Stover
Maybe give it a chance, I put the SE spring in on a whim,(saw it in the new catalog) Took it out after one short ride,But then the stock spring felt weak and I could make it slip in 5th with a heavy roll on the throttle like passing. So I put it back in and added a Diamondback Cable, Got used to it in a couple days. now it feels normal and that thing really hooks up.I like it a lot.
equandt's Avatar
equandt
I'm using the SE clutch spring with the VPC clutch on my Ultra. I tried the SE clutch spring by itself but sitting in Chicago traffic hanging on the the SE clutch spring was a killer on my hands.
The SE clutch spring does break in a bit but working the clutch for an hour or so in traffic requires a tougher hand than mine.
The VPC clutch makes my SE clutch spirng pull like stock. Here is the link to the FM page where you can find them: http://www.fuelmotousa.com/harley/en.../fm-vp019.html
Good luck.
Old Jan 19, 2015 | 11:06 AM
ridedaddy's Avatar
ridedaddy
Thanks for the info on the vpc. Does anyone have any expirience with the coil spring conversion from Barnett or with the pull on the scorpion clutch?
Old Jan 19, 2015 | 12:50 PM
wingfoot's Avatar
wingfoot
I just got through a cam and SE clutch spring upgrade. I used the clutchWIZ and it is super easy to pull the lever. It was a concern at first it felt so soft. After a few hundred miles or so I can say that I can't get it to slip and the pull is super soft. You can add the WIZ without pulling off the primary. Just pop off the Derby...best $115 I have spent.
Old Jan 19, 2015 | 01:08 PM
Belanger14's Avatar
Belanger14
Originally Posted by wingfoot
I just got through a cam and SE clutch spring upgrade. I used the clutchWIZ and it is super easy to pull the lever. It was a concern at first it felt so soft. After a few hundred miles or so I can say that I can get it to slip and the pull is super soft. You can add the WIZ without pulling off the primary. Just pop off the Derby...best $115 I have spent.
So you can still get it to slip?
Old Jan 19, 2015 | 01:29 PM
ridedaddy's Avatar
ridedaddy
Normally with a clutch wiz I think they recommend a 480lb spring.
Old Jan 19, 2015 | 01:44 PM
wingfoot's Avatar
wingfoot
No I corrected my post. didn't proof read my crap..
I could not get it to come close to slipping in any gear.
Sorry for the screw up.
But knowing what I know now as ridedaddy said, I would have gone with the 480 LB spring.
Old Jan 19, 2015 | 01:46 PM
Belanger14's Avatar
Belanger14
No I corrected my post. didn't proof read my crap.. I could not get it to come close to slipping in any gear. Sorry for the screw up. But knowing what I know now as ridedaddy said, I would have gone with the 480 LB spring.
So you think I should do the wiz with the 480? Who makes those products?
