Cruising RPMs??
Old Jan 19, 2015 | 03:06 PM
fwb35's Avatar
fwb35
My 99 felt the same, at 70 mph I would get the buzz factor hitting 3,000 rpm and higher. I did not want to drop all that money for a 6 speed, I found an overdrive pulley that Andrews makes, its the front drive pulley for the drive belt, it is 2 teeth bigger and lowered my rpm's about 300 at 70 mph, now I am cruising about 2,700 at 70 mph and am much more comfortable, total cost from my indy was about $350 parts and labor. This is one of the best mods I have done to my bike, makes it much more enjoyable to ride going down the highway and on long trips.
Old Jan 19, 2015 | 03:12 PM
Kcdcltd's Avatar
Kcdcltd
Ran 80mph, mile after mile, on a 2003 Road King is owned at one time. Ran great and no problems over 40k miles that I owned it. Change something if you want to but you will be doing it for your peace of mind and not for the bike.
Old Jan 19, 2015 | 03:18 PM
glenc's Avatar
glenc
I really appreciate all the good advice. Especially the ones who said just ride it as is. It gives me piece of mind knowing it can take it.
Old Jan 19, 2015 | 04:31 PM
blackflame's Avatar
blackflame
Jeez I must be doing it wrong, I find my self cruising at 80+ sometimes with the gf on it. rpms well over 3k.
Old Jan 19, 2015 | 04:35 PM
White Ice's Avatar
White Ice
Just like it says in the manual, I don't shift into 6th gear until I hit 55mph.
Old Jan 19, 2015 | 04:44 PM
2500hdon37s's Avatar
2500hdon37s
good greif, at 55mph I'm still in 4th, I wont shift into 6th unless I'm at 70mph and higher and plan to cruise. No way in hell would I lug my bike at 55mph by shifting into 6th then.
Old Jan 19, 2015 | 04:57 PM
Notgrownup's Avatar
Notgrownup
3000 ain't nothing for those bikes , it's the sweet spot.
Old Jan 19, 2015 | 05:23 PM
Dun Roamin's Avatar
Dun Roamin
Originally Posted by 0ldhippie
My old evos would cruise at 85 all day. Don't look at the tach...
Ah, that's the problem. Well spotted. It's an FLHR-P with a tach fitted.
Take the tach off, problem solved!
OP, what else can you tell us about your bike .... which pipes, engine mods, rear pulley teeth no. etc?
Yes, it's at the start of the sweet spot where the cam comes on an max torque is being made.
What is the OP actually wants ... more quiet? To ride at lower RPM? (requires more power)? Are there vibes in the bars? To keep up with bigger cube guys (requires tuning/more cubes)?
But in terms of mechanical sympathy, you're just stroking that cat. Without more cubes, lugging it slower would be worse for it.
Old Jan 20, 2015 | 10:17 AM
RKZen's Avatar
RKZen
I did a NC to CA trip with a couple buddies end of summer. We pretty much set the cruise at 80 every day. The motor sounds good at that speed.
Old Jan 20, 2015 | 12:55 PM
wscott's Avatar
wscott
Originally Posted by glenc
I attempted a search of the forum and didn't find anything (which doesn't mean anything where I'm concerned). If this has been discussed please forgive me. I was curious what is the proper cruising RPMs for my year/size bike. It's a 98 Road King Police. When I am at 70mph my RPMs are at about 3grand. Most of the guys I ride with cruise around 75-80. The rpms seem a little high to me. I find that it feels like I need a 6th gear.
Sorry if this has been beat to death in the past
Glen
Your cruise rpm isnt a problem but if it were my bike it would not cost much to buy a drive pulley that has 1 more tooth on it.
Doing that will reduce cruise rpm by approx 200rpm,thats not a lot but just enough for a little relief / reduction in cruise rpm while still retaining decent perf arround town when taking off too.
I did just that for the same reason on my last bike(06 Roadstar Silverado 1700 v-twin 100flt lbs trq stock!) prior to just buying an 09 FLHTCU w-TW96 with 9,700 original miles on it 11/2014.
You may also pick up a 1 mpg or so in the process like my bike did when i did that.
scott
