Brake pad ?
Old Jan 24, 2015 | 07:09 AM
bobgv's Avatar
bobgv
Default Brake pad ?
When you replace your front wheel on a 2012 SG to a 2014 SG enforcer wheel do you have to replace the brake pads? If so which pads do you guys recommend and who's got the best price. Thanks in advance.
Old Jan 24, 2015 | 07:47 AM
Lowcountry Joe's Avatar
Lowcountry Joe
If the rotors are the same, and the pads are good, then you can keep the old pads. If you go with new rotors, go with new pads. Also with new rotors, always use new rotor bolts.
Old Jan 24, 2015 | 09:34 AM
SpiderPig's Avatar
SpiderPig
Pads are the same rotors are different. If it were me I would use some fine grit sandpaper on both and let them seat.
Old Jan 24, 2015 | 09:46 AM
DTTJGlide's Avatar
DTTJGlide
Same pads, bolt it on.
desertwolf
2014-2024 Touring Models
13
Jun 28, 2019 07:37 PM
00copglide
Mar 1, 2017 04:42 PM
lumberjacker
May 20, 2010 06:14 AM
SG 1
Jun 2, 2009 08:44 AM
MyFirstHD
Nov 17, 2008 08:54 AM
