Guys help me understand tuning
I'm thinking of switching out the Reinhart mufflers to CFR's.
From what I've read, it's recommended to have a tune, even with mufflers due to the heat, gas, etc., etc., etc.
So, suppose, I buy a Power Vision tuner, I assume that will properly tune the bike. Correct?
Let's assume a year from now, I wanted to install full headers, with the same CFR mufflers. Would I (or my dealership) use the same Power Vision tuner, previously bought for this?
What I'm wondering is, anytime I make a change to my exhaust, the bike must be tuned, correct? For sake of finances, can I do muffler first, then tune. Then, eventually do headers, and tune again, using the same device?
Also, if I ever wanted to do cams, will I have to tune again?
There's so much information out on the web. Some is BS, some is difficult to grasp.
Also, what's teh best and easiest tuning device to use. I'm thinking of something that I don't need to connect to my computer but which is truly auto-play. meaning, I just connect the dots and it does the work, without blowing up my bike.
Now, what I don't understand from what you posted is, "I should run a few autotune loads to get it pretty close to your bike." How would i know what's the proper tune? From the concept of autotune, shouldn't the device know what's the proper autotune?
Forgive me, I'm trying to digest all of the terms and knowledge.
Thank you!
Thank you!
Spoke to an indy bike shop owner today, and they have a dynojet dyno too.
A guy came in to the Indy's shop after having spent full bank on some CFR's for his touring bike, said he like they way they sounded.....
A dyno run after install of the CFR mufflers.... resulted in the low and mid range torque and hp going down, with a couple of hp gained on the right of the power curve.
Indy takes down some used (for sale) vance and hines slip on mufflers, takes off CFR's and puts the V&H on.... gained the low and mid back & the dyno run was way better than the CFRs. Customer bought the V&H slip ons and sold his CFR's on ebay.
