2005 Tourpak Removal
Old Feb 19, 2015 | 12:50 PM
phillyrube's Avatar
phillyrube
Default 2005 Tourpak Removal
Has anyone done a tourpak removal with the radio amp mounted under the tourpak? Trying to find a way to do this without having to replace the entire radio system. Intercom/CB is not used.
Old Feb 19, 2015 | 05:42 PM
matt_eglide's Avatar
matt_eglide
Is the amp an aftermarket unit? Either way if I were you I'd investigate installing it in the front fairing on top of the radio with several of the brackets that are available through the aftermarket. This will give you the flexibility to utilize the tour pack as a quick-detach unit to back and forth from touring to stripped down street glide look-alike if you so prefer.
HTH.
-Matt
Old Mar 12, 2015 | 05:48 PM
phillyrube's Avatar
phillyrube
It's a Harley amp, p/n 77179-01, past of the 1999-2005 Enhanced Sound System.
Old Mar 12, 2015 | 08:18 PM
Sledge's Avatar
Sledge
Relocate it to the front inside the fairing
Old Mar 19, 2015 | 09:45 AM
phillyrube's Avatar
phillyrube
Doug hooked me up with the instructions for the Enhanced Sound System for 1999-2005 Ultras. Looks like there is enough room under the fairing for the harness and the amp. Probably be another rainy day project. When I start it I'll post up pics...
Old Mar 19, 2015 | 10:25 AM
matt_eglide
If you're going with a quick-detach style for your tour pak, do yourself a favor and get a couple of correctly sized deutsch connectors for all the wiring that runs up to the tour pak from under the seat. That's what I did for the tail light wiring and speaker wiring and can take the tour pak and pillow seat off and replace them with the low profile seat and passenger backrest/luggage rack in less than 3 minutes and vice versa. Very easy to do with some simple electrical/wiring knowledge. HTH.
nuages
Audio Systems
Jan 29, 2014 05:24 AM
sewerat
Nov 7, 2011 11:32 AM
DinoVelvet
Audio Systems
Aug 9, 2011 09:19 AM
FLTR2008TRIKE
Sep 4, 2009 10:18 AM
sportsterleroy
Nov 3, 2008 07:31 AM
