ACC Switch
Old Mar 13, 2015 | 01:02 AM
slammed05fatty's Avatar
slammed05fatty
Default ACC Switch
i wan't to use the factory ACC switch to control power to my air ride. where are the wires ran from that switch? or are their any connections i need to make that switch actually work? i have never had a use for it so no idea how its set up from factory
Old Mar 13, 2015 | 05:57 AM
Sticky4's Avatar
Sticky4
I'd like to use it to light up my air pressure gauge for my air ride, so I'm subscribed!
Old Mar 13, 2015 | 06:04 AM
just plain john's Avatar
just plain john
There's a 4 wire molex connector under the seat, triangular in shape IIRC. HD sells a matching pigtail, but I don't have a part number
Old Mar 13, 2015 | 08:42 AM
pp6000v2's Avatar
pp6000v2
91843-97 is the part number for the "Auxiliary Power Port Side-Panel Mount". It comes with a cig outlet, but in your instance you would just use the harness pigtail that's included. $30 list, it's a 4-pin Deutsch connector.
If you're handy with fabbing connectors, the housing, socket pins, and wedge necessary to make it yourself would be much less than the price of the kit- but the kit is ready made, just connect the hot and ground wires to your pump or relay.
Old Mar 13, 2015 | 08:51 AM
Weavr99FLHT's Avatar
Weavr99FLHT
The 4 pin connector under the seat is as follows (pre-Rushmore)
Ground
On with ignition
On with brake
On with ACC switch
So, depending on the accessory plugged into it, and it's wiring configuration, will determine when it is active.
On my 99 I used it for additional brake lights then added HD's splitter so had the brake lights connected (on with brake) and heated grips that activated with ACC switch.
On my 08 I use it for 12v port in tourpak that is on with ignition switch.
Old Mar 13, 2015 | 09:36 AM
SeaZund's Avatar
SeaZund
I use the Acc switch to run the compressor on my Air Zeppelin seat (using the aux connector under the seat mentioned above). Get the aux. cigarette lighter kit and use that pigtail to build your interface .
Old Mar 13, 2015 | 11:28 AM
Weatheredge's Avatar
Weatheredge
the switched circuit adapter harness 70264-94a - http://www.harley-davidson.com/store...dapter-harness - is about 10bucks cheaper then the 41843-97 auxiliauy power-port side panel mount - if you have extra needs for switched power in the furture its just an added pig-tail
Old Mar 13, 2015 | 11:35 AM
Joe12RK's Avatar
Joe12RK
or for only $14 you can get 70641-08: http://www.harley-davidson.com/store...-11-7064108--1
SeaZund's Avatar
SeaZund
good to know, I didn't know the harness was available by itself
Old Mar 14, 2015 | 01:19 AM
slammed05fatty
thanks for all the info guys, so if i buy this kit i just have to cut off the end and hard wire it to the new pigtail and plug into the bike?
