Voltage Regulator issues?
Old Mar 16, 2015 | 04:52 PM
CarolinaThunder's Avatar
CarolinaThunder
Default Voltage Regulator issues?
I just recently replaced my stator and rotor on my 99 electra glide classic that currently has about 47k miles on her. For the past month or so I have been riding and the volt meter has been at a steady 14v on all rides and I have had no issues what so ever until now.
Yesterday I went on a group ride of about 200 miles. I noticed the meter would fluctuate between 10 and 14v...I know the battery is good as I had it tested when I replaced the stator, and it is only about a year old.
Does it sound like I am having issues with the regulator now?
Old Mar 16, 2015 | 05:18 PM
grbrown's Avatar
grbrown
In the Tech Electrical section you will find a couple of stickies describing how to check your charging system. You'll need a multimeter, but that should help you identify the culprit. Don't guess what is going wrong, as it can get expensive replacing stuff that is OK.
Old Mar 16, 2015 | 05:23 PM
hdbob2006's Avatar
hdbob2006
I'd check the connection where the reg. plugs into the stator. I've seen a few melted and making poor contact. Then,check your connection from the v.r. at the positive post on the battery.
As far as I know,a v.r. either works,or doesn't.
Old Mar 16, 2015 | 07:05 PM
mkguitar's Avatar
mkguitar
as GR said do the checks in a methodical manner.
the stator should out put 16 to 20 volts AC PER 1000 rpms--- so 3000 rpms should give you close to 48~60 volts AC...not DC )
ohm resistance in teh stator are in the manual for your model but may vary if you have another type stator
the VR converts the AC to DC ... via a diode bridge and THEN limits the voltage to under 14.8- the excess is shed as heat --- that's why it has cooling fins and is mounted in the airstream ( never get a chrome cover for the VR!)
top tip....check voltages AT the battery...the in dash voltmeter is subject to voltage drop in the wiring and will respond to the spots/ lights on off, horn etc.
giving you spurious readings
2.) too many times riders say "the battery is new" and replace a whole bunch of parts...then find out the battery was duff.
also check the cables...I have a neighbor who spent $1300 at the dealer chasing a problem...batteries, stators, VRs...turned out he had a bad cable
$12 fix
mike
Old Mar 16, 2015 | 07:45 PM
Highwayman-AL's Avatar
Highwayman-AL
Please keep us posted as to what you find out. These threads are searched for years to come and a solution we all love to hear for our own trouble shooting. Pictures are always good too.
eske29
Jul 12, 2023 07:52 PM
lefty33
Electrical/Lighting/Alarm
Mar 24, 2018 10:41 AM
flhrbill
Jul 6, 2016 04:14 AM
guitarman023
Shovelhead
Jul 27, 2015 05:25 AM
mpaquette
Aug 20, 2011 08:59 PM
