oil cooler question
Old Mar 16, 2015 | 05:43 PM
harley7316's Avatar
harley7316
Default oil cooler question
Hey was wondering i just installed a harley oil cooler on a 2011 street glide was wondering the instructions said let bike warm up and oil cooler should be warm to the touch.Well install went fine its a little cool it is about 34 degrees any ways started the bike up oil pressure came up to 32 no leaks and let the bike warm up for about 10 -15 mins oil cooler wasnt warm is that because it cool outside?Thanks in advance
Old Mar 16, 2015 | 06:26 PM
Nute's Avatar
Nute
Takes quite a while for oil temp to rise even under load. Quite normal. Ambient temperature will also affect duration. If you have oil pressure and no leaks take bike for a ride. Takes upward of 1/2 hour on road to start showing temp rise in oil even when ambient temp is 70. Not recommended to let engine idle for great length of without air passing over cylinders etc. remember these are air cooled engines.
Old Mar 16, 2015 | 06:39 PM
harley7316's Avatar
harley7316
Thanks just wanted to make sure something wasn't wrong
Old Mar 16, 2015 | 06:45 PM
fabrik8r's Avatar
fabrik8r
Even in the summertime on initial start up, 10-15 minutes of hard riding wont get the oil hot enough to open the thermostat, so 15 minutes of idle at 34F ambient is not nearly long enough to get the oil hot enough to open the 185F thermostat.
Old Mar 16, 2015 | 06:49 PM
Drat's Avatar
Drat
As others have stated, you are fine! Now relax, take that puppy for a nice ride and smile at your work. No leaks and pressure is good. Congrats.
Old Mar 16, 2015 | 08:50 PM
harley7316's Avatar
harley7316
Thanks for the replies
LunaticFringe
Apr 30, 2015 11:26 PM
geargrinder
Sep 15, 2014 06:45 PM
trav hd1
Oil Archive (no new posts)
Dec 20, 2009 09:42 AM
eja
Aug 11, 2009 09:02 PM
Fire4Effect
Jul 19, 2009 07:05 AM
