heated grips VS. handle bar question.
Old Mar 23, 2015 | 01:03 PM
STpwmATC's Avatar
STpwmATC
Default heated grips VS. handle bar question.
Picked up a set of HD rubber heated grips this month. And I have a set of 14s I picked up from HD. Just looking into things further and I saw at the bottom of the Handlebar page it says
"NOTE: HANDLEBARS LISTED WILL NOT ACCEPT H-D OEM HEATED GRIPS"
Does this mean Im 100% S.O.L.? Not sure what OEM stands for.
Drag Specialties P/N: 0601-2266
http://pps.partsland.com/PartsUnlimi.../page_1001.php
http://www.harley-davidson.com/store...ber-hand-grips
Thanks all.
Old Mar 23, 2015 | 01:06 PM
batman.'s Avatar
batman.
OEM is Original Equipment Manufacturer. Ive read on here that some bars had to have the inner hole drilled out and also read on here that apes require longer wires ran for heated grips, hence why it might say it wont fit OEM heated grips. Someone else will be able to help out more im sure.
Batman
Old Mar 23, 2015 | 01:15 PM
STpwmATC's Avatar
STpwmATC
O good! So there's hope! Thanks Batman
Old Mar 23, 2015 | 01:32 PM
Scaredofrain's Avatar
Scaredofrain
The bars all state to be drilled for internal wiring. The grips state that the are not suitable for use with internally wired bars.
Might that be the reason??
Old Mar 23, 2015 | 02:28 PM
J929626's Avatar
J929626
If the handlebars that you ordered work with your Twist Grip Sensor (TGS), then they should work with the OEM Heated Grips.
The install guide for the Heated Grips indicate that you need the following additional parts.
2008 and 2009 models require purchase of additional parts:
Twist grip sensor (TGS) jumper harness 70415-08A (1)
Connector 72902-01BK (1)
Terminal pin 72990-01 (2)
Old Mar 23, 2015 | 04:45 PM
baldguy13's Avatar
baldguy13
If I remember correctly, the HD heated grips said they couldn't be run internally. But mine are and they work great.
Old Mar 23, 2015 | 05:29 PM
J929626's Avatar
J929626
The HD heated grips, that I am familiar with and work with the OEM TGS, always run internally,
reno55
May 20, 2018 07:38 PM
Dazed&Confused
Engine Mechanical Topics
Apr 11, 2018 08:21 AM
macmolly
Oct 2, 2013 12:57 AM
jjr
Feb 15, 2013 09:10 AM
casique
Jul 16, 2009 12:10 PM
