Checking/Adding air to rear spoked wheel
Old Mar 29, 2015 | 08:52 AM
gilbert_roadking's Avatar
gilbert_roadking
Default Checking/Adding air to rear spoked wheel
Hi all,
The placement of the valve on my 2012 RKC rear tire is right between the spokes in the center of the rim, not to mention it is also very short.
The end result is usually letting a lot of air out while I try to check it and then finally over filling and letting air out to the desired pressure.
Entire process is about laying on the ground and usually takes (me) about 10 - 15 minutes. I just don't think it should be this difficult.
I am thinking Harley could have done a slightly better job of placement for this valve like on the front tire which is on the side of the rim.
Anyone have any tips/tricks for how they check air on these tires or gizmos that help? Anyone add an extender or elbow?
Thanks!
Old Mar 29, 2015 | 09:02 AM
jstrenn's Avatar
jstrenn
I use this
http://www.harley-davidson.com/store...stem-extension
I have a street glide so no spokes, but it really helps reaching that rear valve stem
Old Mar 29, 2015 | 09:18 AM
bobg03's Avatar
bobg03
Ditto to the extension. Works equally well on the mag wheel on my Road King as well as the spoked rim on my Wide Glide.
Old Mar 29, 2015 | 10:13 AM
Ibfuelish's Avatar
Ibfuelish
When I check the air in my tires I take the time to look the tire over for damage as well. So I lift the bike on a jack, remove the bags and spin the wheel. Getting that Shraeder valve in just the right position makes all the difference.
I've found that with the bike on the jack and sitting straight up and down with the valve rotated to the 9 o'clock position looking at the right side of the bike, is the easiest.
If I'm not inspecting the rear tire, I still remove the right bag while,it's on the jiffy stand and roll the bike to position the valve at the 9 o'clock position.
The only problem I ever have then is deciding whether I position it at the A.M. Or the P.M. Position. ;-)
Old Mar 29, 2015 | 10:15 AM
13RKC's Avatar
13RKC
Another here with the same story, I use the extension. Still a PITA, but much better than not having it.
Old Mar 29, 2015 | 11:40 AM
sixguns's Avatar
sixguns
A 90 degree gauge makes it pretty easy.
Old Mar 29, 2015 | 12:22 PM
grbrown's Avatar
grbrown
Red face
That's the best solution IMHO. I wouldn't ever again leave a 90 degree extension on the valve, having had a rubber valve stem split, while on tour. We didn't know until after being rescued what the cause was, as I couldn't find any evidence of a puncture - there wasn't one, but the tyre beads had come off the rim, so we weren't going anywhere!
Old Mar 29, 2015 | 12:27 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
honda inner tubes,nice long metal 90 degree. i learned this after having 2 flats from defective tubes,dont get tubes through drag specialties they use cheep made in china tubes.
Old Mar 29, 2015 | 12:52 PM
Ronder's Avatar
Ronder
Originally Posted by jstrenn
I use this
Bingo.... Tried to check my new King yesterday and was saying 'what the heck'
Thanks guys!
Old Mar 29, 2015 | 01:52 PM
fourburgs's Avatar
fourburgs
I use the extension also And have another one connected to my air valve so I don't have to take the saddlebag off to check air pressue
