I just changed tappets, cams, and pushrods in my 2010. At 30,000 miles the wear was basically non exsistent. And wear was equal in front and back. I put them back in as is and have zero concerns.
My 09 Ultra might blow up tomorrow but if it does, I guess I got my money's worth. She's been running for 112,000 miles. I don't have a clue what the tensioner shoes look like. The engine is stock with Stage 1.
Never checked them???
You are playing Russian roulette!
OK here it goes, with the new hydraulic cam chain tentioners mounted on the new billet cam plate, harley used a roller chain on the front (primary) and still kept the link chain in the back, (secondary), with the new billet cam plate you cannot see the rear shoe to inspect it,which is going to wear faster because of the link chain. Smoke and mirrors mother harley, get the orange plastic tentioners out of there, they are unpredictable ticking time bombs FHD
This is exactly why I went with Andrews 21 conversion cams with an S&S cam plate for an 07, and their triple geroter oil pump. Those cams make any older twin cam , to the latest spec, They fit the 88" stock inner cam bearings, and the large outer 07,and up cam plates. I now have roller chains inner, and outer.
Twin cruiser, I just did the shoe upgrade on my bike, yes I used cyco gaskets shoe, fueling oe+ oil pump, baisley spring and plunger, replaces stock oil bypass spring and plunger and is far superior, so in doing this project I had a ton of hours investigating this for I wanted the best bang for the buck, and wanted to do the job right,If you had spent the time researching the tensioner shoe problem like I have, it is very clear that they are indeed time bombs, and for bragging rights I removed the secondary tentioner and put it back on with no special tools, without removing the cams,ride safe ride hard FHD
r
Could you give a little more info on how you replaced the Secondary tentioner , (inside), without having to remove the cam chest and cams ....
I thought you had to remove push rods , (cut old and replace with adjustables, or lift rocker boxes), and lifters , and pull the cam chest to get access to replace the secondary cam tentioner !!!!
If there is a less time consuming way to replace the inside cam tensioner, I'm all ears !!!!!! Cheers..
He said he did not have to remove the cams (from the cam plate) which in itself is a good trick...
I'm sure he did all the other stuff you mentioned.
[QUOTE=lp;14295392[COLOR=Red]]He said he did not have to remove the cams (from the cam plate) which in itself is a good trick...
I'm sure he did all the other stuff you mentioned.[[/COLOR]/QUOTE]
After I re read his post, you are probably right,,,
The older tourers , have bearings in the cam plate, and you have to press in cams to remove and install.
The newer bikes dont have bearings in the cam plate, they are just a push in fit .. Either way, if you want to check properly, or replace the secondary tensioner , cam plate has to be removed to gain access to the secondary tensioner ,( ie , remove push rods and lifter, etc, ) .... For a while there, I thought you guys in the States had some sort of trick , whereby you did'nt have to remove the cam plate to replace the secondary tensioner ... bummer ..... Cheers ..
