Power Commander!!!!!! Help!!!!!
Old Apr 8, 2015 | 06:57 PM
Highranger's Avatar
Highranger
Default Power Commander!!!!!! Help!!!!!
2000 ultra classic (flhtcui) mm fuel injection .In 2004, installed the pc111usb power commander, screaming eagle stage 1 kit and had it tuned ,bike has been running great 50 ,000 miles . Tach sees 74000 miles . Recently Did the hydraulic cam tensioner upgrade(screaming eagle) and boy was I lucky. Tensioners were shot. In doing this also installed the vance and hines headers to a true dual set, from the stock header cross over pipes .Now the bike runs crappy , throwing no codes and with power commander unhooked ,it runs fine, called power commander and they assured me there shouldn't be that much change from stock headers to true duals, if U WANT GIVE US 25 $$ send it back and we can look at it, may need new software, also if u need a new power comander we will discount you( wtf). I know its 10 years old and everyone needs $$ right .Bike ran fine until the uprgrade, Any suggestions>< any one deal with this situation ????
Old Apr 8, 2015 | 07:25 PM
0ldhippie's Avatar
0ldhippie
It is usually the last thing ya changed... What do expect from Dynojet with a 10 year old power commander??? Most outfits would just laugh at ya.
Old Apr 8, 2015 | 08:33 PM
Pitbull2411's Avatar
Pitbull2411
I would probably try a new map for your pcIII, or at least send your current map back to the unit again via your pc.
The header change may be enough to throw it off.
Good luck.
Old Apr 9, 2015 | 07:34 AM
Highranger's Avatar
Highranger
Yes old Hippie, pitt bull, its 10 years old , Seems I have never had problems with the mm fuel injection every one talks about , in talking to Dyno jet, they suggested a near map change , then a zero map if no luck . After pulling the stock headers off (PITA) I said ill never go through this again( thanks pb blaster ,it works )I am presently turning this ride into a street glide .I know the parts for the mm are harder to find but feel in the future I can swap to a carb if needed, thanks. Tony
lostrider06
May 6, 2015 05:45 AM
matchstick30
Aug 17, 2014 11:47 AM
patsfanatic
Mar 2, 2013 03:43 PM
WensGlide
Nov 26, 2008 08:12 PM
viper66
Aug 11, 2007 12:16 AM
