You'll know if the bike's anti-knock system is malfunctioning due to the aftermarket plugs... it will turn on the check engine light and throw a code in that case.
Having said that... why chance it? Buy the plug that is manufactured to operate in the ohm range the anti-knock system is looking for. That would be the OEM spark plug.
Simple answer: 2005 and later Harley-Davidson EFI systems incorporate an "Anti-knock" feature that operates by reading the current resistance through the spark plugs.
The use of any other spark plug other than 'Stock' (6R12) disables the anti-knock feature.
Never heard of that. Not anything in my service manual about it. Followed all the links to where this was supposed to be from and there's nothing there. Seems to be one of those "I read it on the internet so it must be true" things...
From: Western Illinois, land of bad roads, and corrupt politicians
You've never heard of FuelMoto? Look at the second post on that link and you will see that it's not one of those "read it on the internet" things. My PowerVision even has a section to turn anti-knock on and off.
I just bought a set of NGK Iridium plugs and damn, they are nice! I've been using the regular NGK for a long time with no issues, but these iridium plugs are something else! Hardly any pings and the engine runs smoother too!
It is just FM being careful, nowhere do they say use of non-HD spark plugs will disable the ion-sensing feature. And the sepst and tts has the feature to disable, you tune with the feature off then after you are done tuning you turn it back on. At least that how I was told it should be done. You don't want the ecm to retard if you can help it.
I don't think it's a matter of them being careful. There are some plugs that do disable anti-knock. Don't know which off hand. There are so many brands of plugs that they can't research each and every one to be sure they have the resistance needed.
And it's one of those situations where..... plugs are cheap. Why save a buck or two, when you don't have to change them that often. It's like those guys who hunt for O rings from other vendors to save a few cents, rather than just grab a few at the dealer.
If they are so anti-dealer, and anti-Harley, maybe they would be happier with a metric, or a Polaris product.
If they are so anti-dealer, and anti-Harley, maybe they would be happier with a metric, or a Polaris product....... I think I just thew up in my mouth a little.
There certainly could be spark plugs that could fall out of the range. There can be stock plugs that could be bad, I saw that in the above post. Also the gap effects the ability of the ecm to read the "knock" . The safe thing to do is recommend stock 6r12 plugs and use the recommended gap, if i was sending out maps to people Id tell them to use stockers(wires and plugs) so that way it takes much of the guesswork out of any trouble shooting incase there are knock problems. You do notice that fm has their own ion safe spark plug wires, so why can't other plugs and wires be ion safe too? Now I have a dyno tuner that checks all that stuff and I have brought my stock plug wires with me incase my non oem wires cause an issue and have talked with him at length about this ion sensing and if there was an issue with any plug I had in the head I would have been told. Not saying it couldn't happen, just that even with champions and or autolites and non stock plug wires I have not seen any disabling of the ion knock sensor ..................yet, LOL
