Mufflers/Aircleaner
If I've posted it once, I bet I've posted it 43 times...
The FIRST thing a man should do when considering making changes is GET A TUNER. It will help a stock bike, and when you change pipes and or air cleaner, you're ready for it.
Can you run without a tuner? Yes.
Will you blow your engine up running without a tuner? Probably not.
Can you expect to get 50,000 miles out of your engine without a tuner? Most likely.
Will it run correctly without a tuner? No.
Dealers and their parts and service departments are a business, in business to sell motorcycles, and motorcycle parts and accessories. They tell you that you can get away without a tuner, because a LOT of guys won't come off the jack for a tuner, and they're afraid they'll lose sales if they tell you to get a tuner.
Changing the air flow without changing the VE tables is not beneficial. These bikes run lean from the factory, adding a more free flowing exhaust makes them run more lean.
Do what you want, I won't criticize, just trying to offer things to think about.
...but there is a reason I won't buy a used bike as my primary ride...
You have this saved in Word don't you?
Installed the Power Commander V. Much better bike and about 8 HP increase.
Bill
