2005 flhtci
Old Apr 26, 2015 | 02:37 PM
elmerdake's Avatar
elmerdake
1st Gear
Default 2005 flhtci
Friend has a 2005 Electra Glide Classic, injected, that seems to drop a cylinder when trying to ride it normal. If you twist hard, it will get up and run with no issues; but trying to ride at the speed limit, or at any speed consistantly what so ever, it spits and sputters, backfires, etc. He has changed coil, wires, plugs, MAP sensor, TPS, ECM, and ignition switch. But, the problem still seems to happen and will only run when you are trying to accelerate HARD..............
Any ideas anyone? I told him that about the only thing left that I could think of was the harness itself, but we all know how fun that will be to change, not mentioning cost.
Thanks,
Old Apr 26, 2015 | 08:50 PM
Bill03E's Avatar
Bill03E
Take the fuel cap off with it running, and see if there is bubbles in the tank, if there are you need to change the line in the tank, and while at it , change the fuel filter.
Old Apr 27, 2015 | 06:33 AM
elmerdake's Avatar
elmerdake
1st Gear
Thanks for the input. We already have changed the fuel filter and did not notice any bubbles in the tank. Hard to know exactly because it runs so rough, there are many vibrations/waves in the tank. Only runs when reving up. The code is throwing MAP bad, but as I said earlier, he already changed that once.......
Old May 3, 2015 | 04:31 PM
Bill03E's Avatar
Bill03E
Maybe you have a broken wire inside the insulation going to the map sensor.
Old May 3, 2015 | 05:03 PM
jd05flhtci's Avatar
jd05flhtci
or a new faulty map sensor. I have seen new parts fail out of box or shortly after
casper10
Nov 25, 2015 10:24 AM
schuffyman
Sep 25, 2015 12:26 AM
stbobber
General Topics/Tech Tips
May 13, 2015 05:30 AM
casty290
Sep 3, 2014 06:35 AM
dyzlexik
20
Nov 12, 2008 11:52 AM
