sert map
Old Apr 25, 2007 | 01:05 AM
tazman44's Avatar
tazman44
6th Gear
Default sert map
Well after waiting a month my SERT finally arrived.
Now i would like to load a canned map at this point and later when I go with the true duals get it dino tuned.
I have a 07 SG completly stock except for V&H oval slip ons.
what would be the best map for this set up?
In a week or so I will be adding the SC AC, what would be the best map for that set up?
Soon will go with the V&H true dual and at that time will get the dino
Gosh i love this site
Thanks in advance for your help
Old Apr 25, 2007 | 02:52 AM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: sert map
ORIGINAL: tazman44
what would be the best map for this set up? Don't use any map... Adaptive Fuel will compensate....
In a week or so I will be adding the SC AC, what would be the best map for that set up? Use map #78 (159PZ003), and max out the entire CLB Table.....
Soon will go with the V&H true dual and at that time will get the dino.. Good starter map will be #67 (159AE003)...... Let the tuner tweak it...
FWIW, Welcome... Please take a moment and post an intro in the New Members Section...
Old May 1, 2007 | 01:43 PM
tazman44's Avatar
tazman44
6th Gear
I have what I think is the latest version P/N 32117-J and the calibration #78 is listed as file name 159PZ004-A1.MT6.
Is this the same as calibration #78 File name 159PZ003?
Should I still max out all the cells in the CLB table?
This would richen up the AFR in the closed loop operation range correct?
Old May 1, 2007 | 04:10 PM
dingwire's Avatar
dingwire
Stage IV
I too am waiting for the SERT I ordered 4 weeks ago. If you don't mind me asking, where did you get yours from? I ordered mine from Hale's.
Old May 1, 2007 | 04:41 PM
UltraKla$$ic's Avatar
UltraKla$$ic
ORIGINAL: tazman44
The 159PZ004 map has some timing changes, and for the better I might add! Max out the CLB tables like SHB stated and let 'er rip.
puma
Feb 19, 2011 12:05 AM
kwas
Jun 16, 2010 11:33 PM
theroadking
Mar 31, 2008 12:15 PM
Bertk
Mar 13, 2008 05:43 PM
brlowe
Mar 9, 2006 12:49 PM
