Jet part# ?
Old May 4, 2015 | 01:58 PM
artc's Avatar
artc
Default Jet part# ?
Anyone the part# for a #46 and #47 jet Screaming Eagle?
Thanks
Old May 4, 2015 | 02:12 PM
mkguitar's Avatar
mkguitar
i don't have part number.
forum member DAWG is the part number king- you could try a PM.
if it helps you the CV Carb was also used in some Kawa and Triumph models- and dynojet and others sold "tuner kits"- so you may have more options than screaming eagle.
and last resort- a tech with old timey carb tuning skills will have tools to enlarge a 42 or 45 jet to the size you want.
i have such a kit made by Carter carbs for the 60's AFB carb...lots of little tiny hand drills to open up brass
since it is all interactive, do you have the idle screw ( under the plug) adjusted the way you want and the slide and needle correct...both of these will affect the low speed jetting
and..most members here have late models- try a repost on the evo board where men fix things.
the CV carb was used 1990+ on big twins ( 1988+ on sportys )
mike
Old May 4, 2015 | 02:20 PM
96roadking's Avatar
96roadking
You can't just ask for them at a dealer anymore? Try an Indy shop.
Old May 4, 2015 | 02:42 PM
acchd's Avatar
acchd
Here link with slow jets. I've got what's left of kit with many unused main jets I'd used when I did my Fatboy in '02. I used a 48 slow jet for stage 1 back then. If you can use any of these jets I've got left let me know.
http://www.cv-performance.com/harley-pilot-jet/
http://www.nightrider.com/biketech/hdcvcarbappendix.htm
https://www.hdforums.com/forum/multi...9604-00-a.html
Old May 4, 2015 | 03:32 PM
artc's Avatar
artc
Good help. Tried the dealer. They didn't know how to look them up if it didn't come stock.
Thanks Guys!!
Old May 5, 2015 | 11:51 AM
mrfikser's Avatar
mrfikser
http://www.jpcycles.com/search/searc...012733&Ntk=All
here is a 46 and 48 ... I don't think they make a 47
GOGOBECK
EVO
27
Sep 29, 2018 06:19 PM
Joeposillico
General Topics/Tech Tips
May 5, 2018 07:00 PM
RENORRIS
Jan 21, 2011 02:17 PM
the*bear
Screamin Eagle CVO Models
Mar 17, 2008 05:39 PM
harleyj4585
Mar 24, 2007 11:15 PM
