Installed V&H Pro Pipe
Yes, you're better than your before picture at all RPMs but I think a better tune would smooth that puppy out. You're so close to Fuel Moto, I'd take it there to have it tuned, or at least call them for their opinion on it.
Yes yes, I know, you dont ride a chart, but looks to me like you're leaving as much as 10% on the table between 2500 and 4K. 10% in my book is not insignificant.
I have a Power Vision, which is about $450 bucks, and if you buy it from Fuel Moto you get lifetime map support if you make changes to your bike's engine or exhaust.
In almost all situations having your bike tuned is the most optimal way to go (assuming the person doing the tune absolutely knows what he/she is doing), but its expensive.
Having a PV *for me* is a good value because in addition to being a great flash tuner (which means it doesnt stay on the bike, it just is used to flash the map to the ECM), it can be used to monitor many engine parameters, read and clear codes, and even make some adjustments to the tune based on how I ride. And if you want to have it tuned, most competent tuners these days can use the PV.
But there are many valid choices out there ranging from the inexpensive to the expensive.
If you ask "what is the best <X>" on this forum, you invariably get a list of everything that exists.
