gouged my caliper piston. should I replace?
Old May 10, 2015 | 09:15 PM
mupepe's Avatar
mupepe
Originally Posted by lp
It's been mentioned here a bunch of times in other threads that a lot of stuck/dragging calipers are really just extremely dirty dust covers and the outer piston area.
Clean that up real good, test, and you're probably good to go.
This is what I assumed. There was a pretty good crud buildup at the sticking point.
Old May 11, 2015 | 06:08 AM
r136dg's Avatar
r136dg
Mupepe, read past your bike year, my bad. Dot 4 and I'm unsure of seals. Don't have a 2014 parts catalog but you could always call HD. While running it after your fix, as others said, keep an eye on that particular pad. If the pistons still sticking you'll see uneven wear on it early on.
I may be a little over kill on brake maintenance, don't ask why.
Old May 11, 2015 | 06:14 AM
Notgrownup's Avatar
Notgrownup
Bingo ... we have a winner. No problem here. Remove the burrs and proceed with the repair. The area of damage on the piston does not slide down/into the seal and will not be an issue.
This is what I would do also...if the edge is smooth and won't cut the seal go ahead and use it, just sand or file it down.
Old May 11, 2015 | 07:30 AM
bagman1's Avatar
bagman1
+1. Completely fine as is.
+2 from another ASE cert
Old May 11, 2015 | 07:35 AM
sixguns's Avatar
sixguns
Yes, the damage you see is not an issue. What you don't see is the issue and why it stuck to begin with is. Is the conclusion that your front brake caliper stuck,bout locked up your wheel, You unstuck it and put it back on? Not smart in my book. Without seeing the inside of that caliper I would never tell one of my customers " its ok to run".
Old May 11, 2015 | 12:44 PM
hdultra2010's Avatar
hdultra2010
Just try to get the piston out by putting both pads inside and i mean not all the way out jist enough to clean all pistons and smooth that bad one. It is in the edge where thepistin dont go in anyway. Dont pop them out . There is no rebuild kit with brembo. I had one at home tgat i thought yhere is a kit bit it didmt work out. Had to buy new one .
Sportsterd
May 2, 2021 03:59 AM
ThaGlyde
Aug 25, 2016 08:34 AM
cajun1957a
Jul 15, 2016 07:26 PM
Ozark Joe
EVO
23
Nov 7, 2015 03:40 PM
rufasim
May 3, 2015 12:17 PM
