Electrical Weirdness
Old May 11, 2015 | 09:40 AM
lakedrum03's Avatar
lakedrum03
Default Electrical Weirdness
2011 96 SG, 11k
So, went out to dinner on Saturday night. Rode to the local 5-star Cracker Barrel and everything was just fine.
Came out, hopped on and down the road we went. I glanced at the Speedo and it was dead. All of the other gauges were fine. Pulled in the clutch and the bike died. Hit the starter button and it fired right up and idles fine. Made a turn and the turn signals would not cancel on their own. Then I tried cruise control and it was also not working. Needless to say, I was getting agitated.
To recap: No speedo, dies when the clutch is pulled in after cruising, turn signals won't self cancel, no cruise, idles fine when re-started....
Went home, disconnected the ECM and the battery. Checked every fuse and relay I could find, all good. Let it sit for 30 minutes and then hooked everything back up. Everything is working fine now. WTF?
Anybody have an idea on this?
Later,
Seth
Old May 11, 2015 | 10:25 AM
FinalShot's Avatar
FinalShot
Have you done your bars or had your controls off? It sounds like a wire is getting pinched or is shorting out.
Old May 11, 2015 | 11:46 AM
lakedrum03's Avatar
lakedrum03
She is bone stock except for the de-catting.
Old May 11, 2015 | 11:54 AM
TexasMotorcycleRider's Avatar
When you de-catted, were you struck by lightning?
Old May 11, 2015 | 12:02 PM
Mike3970's Avatar
Mike3970
Maybe you could check your battery, have it load tested at the auto store. check all the terminals too for corrosion.
Old May 11, 2015 | 12:13 PM
lp's Avatar
lp
Take out and clean your Vehicle Speed Sensor (VSS).
Check for codes. http://www.fuelmotousa.com/p-29661-h...ble-codes.html
Old May 11, 2015 | 12:21 PM
big-e976's Avatar
big-e976
I've heard of Cracker Barrel, but never a 5 star one.
Old May 11, 2015 | 01:12 PM
lakedrum03's Avatar
lakedrum03
Big E - Every Cracker Barrel is 5 star!
LP - Thanks, will try that.
Mike - Terminals are clean. Will get the battery tested.
Rocket - I made sure to do the de-catting on a clear day!
Old May 11, 2015 | 01:50 PM
fat daddy's Avatar
fat daddy
It's the vehicle speed sensor
Old May 11, 2015 | 02:02 PM
I agree, every Cracker Barrel is a 5 star but I am totally offended by the name. Good luck with the VSS if that's it.
