Wheel change question
Old May 18, 2015 | 05:24 PM
CSS899's Avatar
CSS899
Default Wheel change question
I have a 2012 Ultra Limited w/abs. Thinking about replacing the stock 28 spoke wheel set with the newer style impeller wheels that come on the new Ultra's.
The brake rotors on my 2012 Ultra are fixed. I believe the impeller wheels require the use of floating rotors?
My understanding is I will need to purchase a set of floating rotors for the front (2), rear (1), and perhaps replace the old bearings? Anything else?
Trying to figure out what the approx. cost will be minus the wheels. Appreciate the help.
Thanks
Scott
Old May 19, 2015 | 05:00 AM
grbrown's Avatar
grbrown
I don't see why your rear rotor won't swap over, as the hub fixing appears to be the same as your stock wheel. You will need suitable front rotors, which may be floating. Go to the H-D website and the Shop tab, where you can check the fitting instruction for Impeller wheels and see all the info you are likely to need. If buying new wheels I suggest buying the wheel fitting kits which come with bearings, spacers etc.
Old May 19, 2015 | 12:24 PM
CSS899's Avatar
CSS899
Thank you sir. Appreciate the help.
Scott
rgrecco
Mar 18, 2018 09:37 AM
SC07Bobber
Wheels/Tires
Feb 23, 2018 10:16 PM
fosterpe
Dec 7, 2016 03:27 PM
Jaftica
Dec 15, 2015 08:41 AM
Rabid1
Dec 9, 2013 08:24 AM
