Wheel Swap
Old Jun 7, 2015 | 09:42 PM
rev x 800's Avatar
rev x 800
Default Wheel Swap
I have a 2000 electra glide standard , i have installed a 18x3.5 front wheel from a 2012 street glide with no issues , i am now trying to install a 16x3 rear wheel from a 2006 street glide and i have run into problems , i swapped the bearings and center tube to the 3/4 inch bearings and tube and used my original wheel spacers , installed the wheel on the bike to find the belt rubbing the tire and the wheel tire assembly sitting off center (to the left) inside the fender. Any help on what i need to do to make this work would be appreciated thank you in advance !!!!!!
Old Jun 7, 2015 | 09:49 PM
bigskyroadglide's Avatar
bigskyroadglide
I would check to see if the spacers are on the correction side.
Otherwise you may need to use spacers for the year wheel
Old Jun 8, 2015 | 01:52 AM
tfi racing's Avatar
tfi racing
What size tire are you running?Is your rotor centered in the caliper?
Old Jun 8, 2015 | 11:50 AM
rev x 800's Avatar
rev x 800
The spacers are definitely on the correct side and I am running a 140 90 16 tire
Old Jun 8, 2015 | 10:02 PM
langwilliams's Avatar
langwilliams
if the wheel is centered an the rotor doesn't drag you can try a small pulley spacer. I put one on my 94 softail when I put a deuce wheel on the back.
Old Jun 9, 2015 | 06:38 PM
multihdrdr's Avatar
multihdrdr
Basically a duplicate thread with a different title. See link below for the continuing saga and conclusion.
https://www.hdforums.com/forum/touri...tra-glide.html
BDid
Dec 10, 2015 02:42 PM
rev x 800
Jun 9, 2015 06:57 PM
DG Racing
Wheels/Tires
Jan 5, 2015 10:43 PM
roadkingbigjoe
May 14, 2014 11:43 AM
Mikechk
Nov 14, 2010 10:32 AM
