I new a member and i'm searching to find what's the problem on my Road king flhrc 2001. This week after a little ride, when i tried to restat my bike, the head lamp and the neutral green light don't light and i can't restart it. i look in the fuse box in the left side cover and the fuses are ok. I don't know whats the problem and i need help whit that. I speek french and it's hard for me to explain in english.
Bonjours ŕ vous tous, je suis un nouveau membre et je viens ici pour trouver une solution a un problčme que j'ai depuis cette semaine. Je suis allé prendre une petite ride et tout allait bien sauf qu'aprčs avoir arrčté ma moto elle ne veux plus repartir. La lumičre avant et la lumičre du neutre verte n'allument plus. J'ai regardé les fusibles qui sont dans le couvert du coté gauche et elles sont toutes bonnes. Est-ce que quelqu'un de vous ŕ déja eu ce problčme et comment le réparer SVP
Got to agree with checking the battery. Remove seat and with (hopefully) a quality digital volt ohm meter the battery should read about 12.4 volts. If less than that the battery may well be toast. While you are there check to make sure the terminal nuts are tight.
thank's for your answer the first thing i do was cheking the batterie and i put my charger on it and the batterie was 90 % of it's power. i bought that batterie 3 years ago and recharging it once a month in winter, I'm shure it's not the batterie. My digital speedometer light is on and i can see the km on it.
Thank again for your help
Battery might just have a surface charge on it. Do a cranking test on it. Leave the leads to the meter on the battery and hit the starter and see what the battery voltage drops down too. Anything below 10 volts and it's bad.
Welcome and your English is way better then my french ever will be so no worries about your Grammer we understood you.
My battery test is 12.6 amps it's not the batterie. So iM still searching the problem. just neer the batterie thers a fuse i knok on it and the light come back on and i think i found the problem but after an other ride i can't start it again. i check the metal fuse and it's look good. Sorry for long time i restart to work and i'm was verry busy. i still need help to find what's the problem.
thanks for your help it was verry appreciate
Possible loose connection, maybe replace inline fuse set up
