Which tire gauge do you prefer?
Old Jun 12, 2015 | 08:57 AM
  #31
Pix's Avatar
Pix
I think it depends on the air you are using...if you fill with nitrogen then the accuracy of the gauge comes into play I know you get better mileage with helium, plus it make you talk funny!
Old Jun 12, 2015 | 09:10 AM
  #32
Uncle Larry's Avatar
Uncle Larry
A gauge is a means of checking the pressure, but accuracy can be a problem especially from one gauge to another. Milton and Schrade are two of the long standing and quality pencil type gauges. The more important factor is that you used the same gauge ... thereby establishing a reference point to use should you encounter a tire problem ( attributable to pressure ) you'll have a base pressure setting and can go from there.
Old Jun 12, 2015 | 11:04 AM
  #33
Brewmany's Avatar
Brewmany
Originally Posted by Pix
......I know you get better mileage with helium, plus it make you talk funny!
You get even better mileage with hydrogen, it's a bit lighter- and it's cheaper and easier to find. Just don't pull a Hindenburg..............
Old Jun 12, 2015 | 11:39 AM
  #34
CipoWins42's Avatar
CipoWins42
Originally Posted by RushKing14
I use this one. It is great. Has a foot long hose and a right angle chuck, making it real easy to get on the valve stem. It also has an air release button, so you can overfill a bit, then let the air out to the desired level.
http://smile.amazon.com/Accu-Gage-RA...0+degree+gauge
Old Jun 12, 2015 | 12:45 PM
  #35
son of the hounds's Avatar
son of the hounds
Next time you change your tires, change the valve stem on the rear to a 90, then use any old air gauge you want.
I have several "hi-end" gauges in digital and dial analog. All are close to one another, less than 1/2 pound difference, so I leave the $ 1.99 HF in the bike for trips and use the H-D dial, clip and hose at home.
Old Jun 12, 2015 | 04:22 PM
  #36
Uncle Larry
Great idea unless you have spokes ...
Old Jun 12, 2015 | 04:37 PM
  #37
dyna rider's Avatar
dyna rider
Default Tire Pressure Gauge
Been using this one about 8 months and it works great but a little spendy.
Amazon.com: Longacre Liquid Filled Deluxe Tire Gauge 0-60 psi: Automotive Amazon.com: Longacre Liquid Filled Deluxe Tire Gauge 0-60 psi: Automotive
Old Jun 12, 2015 | 08:42 PM
  #38
themensh's Avatar
themensh
To avoid voiding my tire warranty, I use a Harley Gauge.
Old Jun 12, 2015 | 10:04 PM
  #39
lh4x4's Avatar
lh4x4
I have about a dozen of the pencil type that were advertising hand outs and some one dollar ones. From time to time I check a tire with all of them. So far they all have read the same. So I trust them. Some times cheap works well.
Old Jun 13, 2015 | 12:51 AM
  #40
mcain49's Avatar
mcain49
Originally Posted by Ron750
I detest most pencil tire gauges. I have been using Miltons since 1978 and they work great, but they keep getting harder to find.
Still made in USA!
http://www.summitracing.com/parts/mli-s-921
I've used Miltons for years as well. Saw them recently for sale at Northern Tools. I have one that i got back in the 80's that still works great.
