Hot or Cold at oil changes ?
Old Jun 12, 2015 | 08:48 AM
lionsm13's Avatar
lionsm13
Wow!!
Is it winter already?
Old Jun 12, 2015 | 10:39 AM
SH_01FXDWG's Avatar
SH_01FXDWG
Originally Posted by lionsm13
Wow!!
I don't get it ?
Good input guys. I always drain when hot too. Just curious what other thought.
Going to install a HD OEM Super Premium Oil Cooler this weekend that I picked up from a friend. Doing all the fluids at the same time.
Old Jun 12, 2015 | 10:57 AM
Brewmany's Avatar
Brewmany
I drain hot, then go in the house and get a beer while it's draining ... Fixed it for you :>)
I drain it hot, then go into the house and get another beer while it's draining.
Gotta have the first beer while assembling the tools and parts.........
Fixed it for YOU
Old Jun 12, 2015 | 11:20 AM
son of the hounds's Avatar
son of the hounds
Originally Posted by SH_01FXDWG
Hey Folks, I'm always thinking it would be better to drain it cold, after anything that may be in the oil has settled to the bottom.
Hot circulating oil puts the combustion and friction particles in suspension so they flow out in the oil. When cold, the parts have settled and are not removed my cold draining. It is better to have very hot oil than very cold oil, not because it will drain better, but because it will remove more wear and tear particles caused by the heat and friction.
Warm is okay as most combustion and friction particles take hours to settle out. Your magnet should remove any metallic particles and are not the concern for oil changes. They should be captured by the drain magnet every time you run your engine.
My $0.02 and nothing more.
Old Jun 12, 2015 | 11:46 AM
RK14SGS's Avatar
RK14SGS
You don't have to change oil if you use synthetic. It could never possibly break down. Ahem...
Now back to the beer...
Old Jun 12, 2015 | 04:06 PM
Pix's Avatar
Pix
I always have a cold one while draining the hot oil.
Old Jun 12, 2015 | 04:45 PM
chamokie's Avatar
chamokie
Originally Posted by 62hdbiker
plus if you do it hot and restart the bike afterwards there will be less time for the oil to drip off internal engine parts - before circulating oil fills the oil filter and pressurizes the system. since filter is sideways you cannot pre fill it and your system gets no oil until its filled
I disagree with the filter part. NO filter should be put on dry. If you do then the engine runs with out any oil for a number of seconds, that is not good.
Even if you partially fill the filter, it will start circulating immediately.
I fill mine, if you are fast enough you loose very little, and the engine is fed instantly.
Just my .02. Been swinging wrenches for 55 yrs, have an idea of what I am doing. Same goes for cars.
dyna rider's Avatar
dyna rider
Default Oil Drains
I sometimes let mine drain all night along with the filter with holes in it. Usually nothing to drip on the front mount if it drains for hours. I do start out with hot oil.
Old Jun 12, 2015 | 06:44 PM
Dsm Limited's Avatar
Dsm Limited
Even if you partially fill the filter there is a lag between engine running and oil flowing, although it's quicker, still a lag none the less.
Either way, you'll hurt nothing. You're draining oil, not wiping the cylinders and bearings clean.
Old Jun 12, 2015 | 07:56 PM
CSMHOG's Avatar
CSMHOG
Perfect response.
