Progressive 944 settings
Old Jun 13, 2015 | 10:32 AM
rowle's Avatar
rowle
Default Progressive 944 settings
All,
I wanted to start this thread to get some idea of settings people are using on their progressive 944 shocks as i cannot get mine right.
My data;
Solo - 185 lbs - standard srings - no turns
2 up - total 380 lbs - 4 turns
Thanks everyone for the help
Rowle - uk
Old Jun 13, 2015 | 12:03 PM
Bikerscum's Avatar
Bikerscum
'15 Limited Low, solo only so far...
235 lbs, STD springs, 5 turns. Still get some bottoming. Although I might be confusing bottoming for just adjusting too stiff. I need to put some sharpie marks on the piston rods & go for a bumpy ride.
Old Jun 13, 2015 | 07:04 PM
Buelligan666's Avatar
Buelligan666
2011 Electra Glide
Had mine set at 5 lines. 2 up 345 lbs total. Standard spring. Road like a dump truck.
Backed them off to 2 lines showing. Nice smooth ride. Get a little bottoming. Probably need to turn them up half a turn or maybe a full turn. I don't change them for solo riding. I have a Softail for that.
Progressive tech told me when I called, to set the preload so the shock measures 11.5" eye to eye when loaded. 3/4" of sag. There's another thread about it somewhere..... Oh that was you rowle!
Old Jun 13, 2015 | 10:50 PM
Bikerscum's Avatar
Bikerscum
So I did some more playing with settings today. I cranked them all the way up... like 8+ turns and the "bottoming" didn't really get any better. Turns out I was right before... I was confusing bottoming with stiffness & compression dampening. I backed them off to 2 turns, much much better. Tried 1 turn & did get some actual bottoming so went back to 2.
One thing about these shocks.... even cranked all the way up, at 235 pounds I still get some sag when sitting on the bike. I could bounce up & down & move the swingarm. With the factory 12" hand adjustables, nothing would make that swingarm move while sitting, at any setting.
Now I have to go treat the skinless patches on my hands from cranking those knurled adjusters up and down.
Old Jun 14, 2015 | 07:35 AM
mainboom150's Avatar
mainboom150
progressive has a video on there site on how to set your sag might wanna watch it. its different for everyone
Old Jun 14, 2015 | 08:35 AM
MikeTD3's Avatar
MikeTD3
944 std spring
Solo- 170lbs 1 1/2 lines showing
2up- 290lbs I either leave it or for long runs and another turn
I've found the shocks to be very sensitive to minor preload adjustments, but coming from a dirt bike background I'm picky about suspension settings.
Old Jun 14, 2015 | 09:13 AM
bagman1's Avatar
bagman1
Originally Posted by MikeTD3
944 std spring
This solo setting is what I use to use then add a half turn when using the tourpack.
Old Jun 14, 2015 | 09:53 AM
jason605's Avatar
jason605
944 std spring
Solo- 210lbs = 2 full turns
2up- 360lbs = 4 full turns
Old Jun 14, 2015 | 10:08 AM
rowle's Avatar
rowle
Thanks for the replies so far.
Looks like the data is forming a pattern.
When we get more data, i will try and form a chart for the 944 settings vs weight.
Thanks all.
Appreciated.
Rowle uk
Old Jun 14, 2015 | 10:37 AM
Bikerscum's Avatar
Bikerscum
lol... this thread has already taken a confusing turn. Big differences in settings from users with more or less equal weights. Here's the thing... some are posting "turns", some are posting "rings". There are 2 turns to a ring. So, a setting of 4 turns IS a setting of 2 rings, not twice as stiff as it seems on the surface.
